Top 10 SDA's
engtaz
engtaz Posts: 7,669
edited May 2007 in Vintage Speakers
Could we get options of Top 10 SDA's, use Generations, start with best and go down to the 10th best:
engtaz
engtaz
Post edited by engtaz on
  • ND13
    ND13 Posts: 7,601
    edited March 2007
    SRS 1.2 TLs
    SRS 2s
    SRS 2.3TLs
    CRS+s
    SRS 3.1TLs
    SDA 1Cs
    SDA 2Bs
    SRSs(originals)
    SDA 1Bs
    SDA 1As
    Just my $.02
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • read-alot
    read-alot Posts: 812
    edited March 2007
    You will get alot of opinions.
    I will get back with you when I have owned all of them
    and heard all of them in the same room with the same setup.
    Read the 2nd paragraph of polksda's reply below. He nailed it.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2007
    Only from what I've owned/heard:
    1.2 TL's
    3.1 TL's
    SRS 2's
    1B
    SRS's
    SOPA
  • polksda
    polksda Posts: 716
    edited March 2007
    ND13 wrote:
    SRS 1.2 TLs
    SRS 2s
    SRS 2.3TLs
    CRS+s
    SRS 3.1TLs
    SDA 1Cs
    SDA 2Bs
    SRSs(originals)
    SDA 1Bs
    SDA 1As
    Just my $.02
    2B over SRS? No way. The 2B is a nice little speaker, but in no way above the SRS, in my opinion. It's interesting that you put the 1st and 3rd generation SRS on the list, but not the 2nd, the SRS 1.2 (non-TL).
    Methinks that's there's no way to make a definitive list as (1) very few folks have heard several sets of SDAs, let alone the majority of models, (2) it's subjective anyway, and (3) it depends what criteria you're measuring.
    I currently own 1C, 2A, 2B, and SRS 1.2. I'd put the 1.C at the top for musicality, but the SRS 1.2 at the top for raw "OOMPH!"
  • madmax
    madmax Posts: 12,434
    edited March 2007
    From what I've heard in my livingroom I'd have to say:
    SDA-SRS (w/ rep tweets)
    SDA-SRS 1.2 (w/ rep tweets)
    SDA-SRS
    SDA-SRS 1.2
    SDA 1C (w/ rep tweets)
    SDA-SRS 2.3
    SDA-CRS+
    The replacement tweets cause any of the SDA series to move up a few notches over an orig tweeter model.
    Vinyl, the final frontier...
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2007
    1.2 tls upgraded tweets x-overs
    was there anything else before these
    I cant remember....
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • read-alot
    edited March 2007
    SDA-SRS
    SDA-SRS 1.2
    SDA-SRS 2.3
    SDA-CRS+
    Exactly :) and changing the caps out take them to another level - I am told.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • madmax
    edited March 2007
    I have not changed any of my caps but I've heard ones which have been changed. Another level for sure. Every bit as much change as the tweeter change itself.
    madmax
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Thanks for the input and please keep the info coming? Everyone's idea are appreciated and respected.
    Thanks,
    engtaz
    engtaz
    F1nut Posts: 51,699
    edited March 2007
    Mine are the best, period.
  • shack
    shack Posts: 11,154
    edited March 2007
    The best SDAs are the 1Cs with the upgraded tweets!
    (Because that is what I own!)
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    I've heard most of them in my travels and the SDA SRS 2 and SDA 1C set the bar for the group. You'll get everything you need SDA wise from those models.
    The SDA SRS 2.3TL does everything the SDA SRS 1.2TL does and the SDA CRS is just plain fun.
    If I had to choose....
    SDA SRS 2.3TL
    SDA SRS 2
    SDA 1C
    SDA CRS or SDA CRS+
    Obviously that excludes models but the rest don't really hold a lasting impression for me. These were the models that really made me think and have fun.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    SRS 2
    SRS 2.3TL
    CRS+
    2B
    I've heard them all, short of early versions that used a dimensional tweeter(s) also, and the 3.1TL. The 1.2TL's never did for me what the SRS 2 and 2.3TL did. The only non-reference series model I like is the 2B, and half of that is just the simplicity of it, perfect size, good bass weight, and great imaging. Plus, they are the speakers that I popped my SDA cherry with.
    Cheers,
    Russ
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2007
    SDA SRS 2.3TL
    SDA SRS 2
    The SRS 2 is as good as it gets, the 2.3TL just adds more of it.
  • Deadof_knight
    edited March 2007
    And the 1.2's add more of more !!!
  • ESavinon
    ESavinon Posts: 3,067
    edited March 2007
    My list:
    SRT.
    Sda srs 1.2tl
    sda srs 2
    sda 1c
    sda crs +.
    I've heard them all and these are the ones i've bought.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • Neskahi
    Neskahi Posts: 297
    edited April 2007
    So! I use regular old 2.3's with upgraded tweet's. Where does this fit?
    Am I really missing anything.
    FYI
    "Neskahi" is the name of a canyon at Lake Powell in Utah. Been asked what it means several times.
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    edited April 2007
    Still in the market for 1.2TL's. Will pay a premium for a quality set.
    Location, Oklahoma.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • snow
    snow Posts: 4,358
    edited April 2007
    Neskahi wrote: »
    FYI
    It is also a navajo word. Not sure what it means being that i dont speak navajo, but im sure if someone is intrested they can google it.
    REGARDS SNOW
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2007
    My list based on the SDA's I have heard.
    2B's all the way:D
    But I think I would like to own a pair of 1C's next.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    Other than cosmetics, is there much sound difference between the SDA 1b's and SDA 1c's??
    I have a set of 1b's that I need to have new cabinets made for. For the cost of having the cabinets remade, I could probably get a set of 1c's if there is a sound improvement to go along with the cosmetic change.
    Michael
  • dorokusai
    edited April 2007
    2B's all the way:D
    Really? I just so happen to have a pair :D
  • MillerLiteScott
    edited April 2007
    I know you do.
    tonyb Posts: 33,068
    edited April 2007
    Have to agree on the 2.3's with the rest of you.The 1.2's and the
    mighty SRT never did it for me either,musically speaking of coarse.
    HT is a whole 'nother ballgame.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Out of most the SDA's I think that the 3.1TL's have the best chance to pass the WAF.
    engtaz
  • avguytx
    avguytx Posts: 1,628
    edited April 2007
    Well, I guess I broke my cherry on owning a pair of SDA-1C's so I can't throw an "educated opinion" into this topic other than I love my 1C's. One day I will own other pairs I'm sure but for now, these fit into my 2-channel listening room well. They aren't too big or too small.
    I do remember when the original SDA SRS's came out and hearing them for the first time back in 1985 or so. I was hooked and here I am.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • Phil Dawson
    Phil Dawson Posts: 288
    edited April 2007
    The best ones are the ones you are lucky enough to own or have a chance to buy. I have a pair of SDA SRS and a pair of 2.3tls. They both sound great and work together very well in a 5.1 music system. There is always something better out there or a way to improve what you have - but what you do have may not be so bad either.
    Phil
  • madmax
    edited April 2007
    Lasareath wrote: »
    The amp I am using now is only 110 watts by 7 and I think that the 1C's sound pretty good with it, but it may not have enough power to make the 1.2's sound very good.
    You will be pleasantly surprised. Since the 1.2's are more efficient they will do more than the 1C's with the same power. It will sound like you have a bigger amp.
    madmax
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    1 watt = 91db
    2=94
    4=97
    8=100
    16=103
    32=106
    64=109
    128=112
    256=115
    512=118
    Any questions?:p
    They are very efficient with HIGH CURRENT amps:)
    The key is high current. Without that the watts don't mean much.
    Also the 1.2's are "compatible with 8ohm amps", and are more like 4ohms. They actually have less resistance than the SDA-SRS's that are rated at 4ohms. But they do work with 8ohm amps because they are so efficient. BTW most "4ohm compatable receivers" are just limiting their current.
    Ben
    F1nut Posts: 51,699
    edited April 2007
    The 1.2TL, 2.3TL and 3.1TL are 6 ohm nominal.
    How can you spell current correctly once and then spell it twice as currant in the same post? Got jelly on the brain?
