Mid-Woofer Dented Dust Caps - Repair
Does anyone have a method to remove the dents from my mid-bass driver's dust caps. I have two that are dented in and I want them to look good again.
Garage System - The only room where I can "Turn IT UP"
HK Receiver/CD Changer
Polk SDA SRS2
Polk RTA 15TL
Polk SDA SRS2
Polk RTA 15TL
Post edited by hqdb on
Use some sticky tape to pull the dents out.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
A vacuum cleaner hose has also been known to work this out.
+1Polk65 wrote:A vacuum cleaner hose has also been known to work this out.
I have done many this way
Ben -
Obviously you don't own a real man's vacuum cleaner! There would be nothing left of the driver if you tried that with my vacuum cleaner
DKG999
