Plasma wall mount cable management?
disneyjoe7
I wish to mount my Plasma to the wall running all wiring in wall to floor area. This floor area hole will work to a new equipment rack does anyone know of a nice cable hole system for this purpose? I wish to have just 1 - 10' cable between Plasma and source or is this a bad idea?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Ok, here's what I'm thinking if nothing better. Two Low voltage old work boxes mounted sideways so they are larger left to right not up and down. One behind the TV, and one behind the equipment rack. This way all cable run down in wall to equipment below, not so pretty but it will work.
Anything to make it nicer looking, or any other better idea?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
So you wall mounted Plasma people how did you do yours?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I see this tread will be like the Babes tread a heavy response Wall.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
www.wiremold.com should give you some ideas. It is available at Lowes.[
Thanks, but what I seen on that site is something that mounts to wall to bring down. What I'll be doing is fishing down wiring in wall to bring down, looking for a nice wall hole dresser so too speak. This way the Plasma will look like it's hanging in mid air.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sounds like your idea will work. Have you verified that there will not be any cross pieces in the way? I'm not sure what you call them, but I know in some walls there will be a cross piece (approx. 14in wide) that goes between the studs, I guess for reinforcement. Maybe they are only used if the wall is load bearing, I'm not sure.Robert
zombie boy 2000 wrote:You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's -
Positive, but even if there's one I will have a 3/4" hole in it after I done. Gotten really handy drilling holes in fire stops or drywall nailer's as I call them for that too stop me. Others nailer's are about the 6' mark Plasma will be about 4.5' so there should be a problem with that.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Nothing custom on the market? I know there's some high end installers here, I would think someone would have came up with a nice looking idea by now.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
You'll be needing 2 cables. The first is your signal/cable TV the second will be the power cord. The cleanest way is to use 3 cut-in boxes. Cut your first pair of holes on each side of a stud behind your plasma. The one for power needs to be above an existing power outlet. You can go vertical or horz. with your box layout, doesn't matter as these are behind the plasma. Kill the power and fish a piece of 12-2 romex from the existing plug up to the new hole, install a cut-in box and trim it with whats known as a "clock outlet". Then tie in the wire to your existing circuit. On the signal side, cut a third hole below the upper, same elevation as your existing plug. Fish your cable from hole to hole, and install the cut-in boxes.disneyjoe7 wrote:I wish to have just 1 - 10' cable between Plasma and source or is this a bad idea?
I am an electrician and I do these all the time.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
Sony 60GB PS3, Blu-ray Disc
TiVo Series 3 HD
Universal Remote Control MX-900
Polk Audio LSi9 ebony, fronts
Polk Audio LSiC, center
Polk Audio LC65i in wall, surrounds
SVS PB12-Plus Piano Black
Outlaw PCA interconnects
BetterCables for HDMI & SUB
Master Bedroom
Sony KDL-46XBR4
Sony 40GB PS3, 2nd Blu-Ray Disc
Polk Audio i-Sonic -
cyberhazard wrote:You'll be needing 2 cables. The first is your signal/cable TV the second will be the power cord. The cleanest way is to use 3 cut-in boxes. Cut your first pair of holes on each side of a stud behind your plasma. The one for power needs to be above an existing power outlet. You can go vertical or horz. with your box layout, doesn't matter as these are behind the plasma. Kill the power and fish a piece of 12-2 romex from the existing plug up to the new hole, install a cut-in box and trim it with whats known as a "clock outlet". Then tie in the wire to your existing circuit. On the signal side, cut a third hole below the upper, same elevation as your existing plug. Fish your cable from hole to hole, and install the cut-in boxes.
Thanks, Cyberhazard some great info on this subject and has given me some additional cable management idea's that I needed for the Plasma. Just one thing if I have 14/2 in the existing outlet box now I would need to run 14/2 out not 12/2 right?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Correct. If you existing circuit is 14-2 then 12-2 would be overkill. In my area, new homes are wired 20A for plugs an 15A for lights.
BTW
Orlando. I am originally from Titusville. Bought my last ride a Massey Cadillac right off the B-Line in Orlando while on vacation in 06.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
TiVo Series 3 HD
Master Bedroom
Sony KDL-46XBR4
Well I think you're right 12/2 is being used for plugs, maybe even lights. I been doing a lot of work in attic and found maybe 2 14/2 cables in the whole house. But I believe you can't mix romex in a box if now 14/2 I can't add 12/2 well I least I think I'm half right.
BTW Massey Cadillac off B-line in O town, then that is what we call "OBT" or 441 Orange Bloosom Trail it's 10 miles from me.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sure you can. Your only limitations are,disneyjoe7 wrote:But I believe you can't mix romex in a box if now 14/2 I can't add 12/2 well I least I think I'm half right.
1. Are the current carrying conductors equal to or greater than the branch circuits rated capacity.
2. Will the size of the box in question support the addition of more conductors.
For example, say your existing box is listed at 25 cubic in. Each #12 wire requires 2.25 cu. in. of space in that box.
Therefore you can safely fit 11 wires in the box. Oh, and all grounds added together equal one wire as far as box fill is concerned.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
TiVo Series 3 HD
Master Bedroom
Sony KDL-46XBR4
Gotta thanks
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I found "Recessed Low Voltage Cable Plates" at www.datacommelectronics.com, Phone #770-6628205. They have single,double, and tripple gang box wall plates with a "chute" cast into the rear to guide the cables through. For a wall mount, you can turn the plate so that the chute faces down at the bottom and reverse it to bring the cables up at the top.disneyjoe7 wrote:I wish to have just 1 - 10' cable between Plasma and source or is this a bad idea?
These look real slick and could be attached anywhere on the wall with screws and drywall anchors.
Don -
I got lucky with mine. As stated you will need a box to plug the unit in. I ran wires to a box between the same studs to the next room for which i mounted the tv. i then installed a box behind the plasma. All remaining wires were ran in the wall down from the tv to the floor stud. I made a small hole and ran all wires behind plastic molding for wires which lowes sells. You cannot see one wire. I was worried about having all wires together, but this worked fine. This i would say was a first class job. Good luckOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Beautiful thanks just what I was looking for, will look so much better than the orange old work low voltage gang box.
So between Cyber and your self Don I'm GOLDEN.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
doug lang wrote:I got lucky with mine. As stated you will need a box to plug the unit in. I ran wires to a box between the same studs to the next room for which i mounted the tv. i then installed a box behind the plasma. All remaining wires were ran in the wall down from the tv to the floor stud. I made a small hole and ran all wires behind plastic molding for wires which lowes sells. You cannot see one wire. I was worried about having all wires together, but this worked fine. This i would say was a first class job. Good luck
Well my first thought was to run all cables for TV in one hole behind it, to a box behind a low boy entrainment cabinet. I was including Power cord with this. Cyber gave me the idea of adding a third box for AC power, alone with the two other boxes. Now what Don found this also will have a very clean look, needed for the WAF.
The wall behind this is my master bedroom which isn't going to work for anything in Family room that would be a NO NO.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I have a low eq cabinet below my plasma, probably 2' tall. I have a two inch hole behind the plasma, and a two inch hole behind the cabinet, all my cables run behind the wall through those holes and into the cabinet. No muss, no fuss, as long as you don't need to get behind the cabinet. Be sure to leave extra cable, so when you need to get behind your cabinet, you don't pull all the cable work out of your eq (I hate when that happens).My equipment sig felt inadequate and deleted itself.
I just saw this thread. My wife wants me to mount the 50" plasma and the Surroundbar on the wall. I was wondering how this was going to get done. Thanks for the info.
Rivrrat wrote:Be sure to leave extra cable, so when you need to get behind your cabinet, you don't pull all the cable work out of your eq (I hate when that happens).
Great point I may need to rethink my cable lenghts over. I was thinking 3 meter but maybe 4 now? I thought after 3 things can have a little loss?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I don't know about you folks, but having an electronics background, I don't like any more splices or connections in the signal path than is absolutely necessary. The fancy wall plates with specialty connectors look nice, but they add connections in the signal path and they are down right expensive. While I have absolutely no affiliation with the company or product below, I’m going to use it in my next build out. I think it reduces unnecessary connection points and dresses the wall plate. I’m not sure how they would look located higher than 2 foot of the floor though? They also have a dual wide if you have a lot of cables. Prices are very reasonable.
To check out these, go to Skywalker.com. They have a lot of products related to installation of Audio/Video. The guest sign in is: sw, password is 2savemore.
I have included a pic of the single gang cover.
Thought it might help you manage the spaghetti......Conrad Johnson PV14L
Rotel RCD-1072 CDP
Carver TFM-25
Polk SDA 1C's with upgraded xovers -
C3 Audio,
I agree with you on signal path and connections, this is why I wanted to have 1 -10' cable for TV to STB.
Take a look at the product that DAMCB / Don found has a more refine look to it. IMO
This is not the manufactures website but a reseller which list a very nice price for this plate.
http://automatemyhome.com/products4-2.asp?CustComKey=73491&CategoryKey=79663&ProductKey=226292
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:C3 Audio,
Another good wrinkle.....Thanks for passing it along. Certainly gives us more options than we had before.Conrad Johnson PV14L
Rotel RCD-1072 CDP
Carver TFM-25
Both options are better looking than my wall mounted computer grommets. But the grommets do finish off the hole.
Oh, and I agree about the less mechanical connections the better.My equipment sig felt inadequate and deleted itself. -
disneyjoe7 wrote:So you wall mounted Plasma people how did you do yours?
stick the bracket on the wall and mount the lag bolts to the frame of the mount. (predrilling holes, of course) mount the clips to the backside of your tv. make sure they are level and then stick your plasma up there and level again to make sure it needs no adjustments. voila!At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
I used a stud finder. Mine were 18 on center. One thing make sure you hit the stud dead center with your lags. My plasma weighed a ton.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
The hardest part of the process was lifting the plasma up to the bracket, and then making all the connections.
A small mirror would help with thatMy equipment sig felt inadequate and deleted itself. -
So here's a question(s)... I know my studs are 24" center, my set is 42" so should I go with a mount that is made for 27"-42" or one that is more like 37"-50" for greater wiggly room. Greater play to make the set center? Or will I need to add support behind the set for this mount?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I would go with the wider mount. This way as you say you have more to play with the studs. You do have play with the mount from left to right. Mine was a two man job. I got the tilt mount so after it was hooked on, i tilted it and there was room for the connections.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
