Compaq Computer processor upgrade
josh_parsons626
I dunno if this was the right place of it this is topic is accepted here at CP. But I have an old Compaq Presario S4020WM that my father-in-law gave to me because the hard drive had been destroyed by a virus. Well I bought a ?180? gig hard drive (I think it's that big) and added an additonal 256mb strip of RAM which before it only had 1 strip of 128mb. I will eventually take out the 128 and put in another 256 then I think that's the most I'll ever have to put in. The next thing I'm wanting to do is upgrade the processor, but that's one thing I dont know how to do. Can somebody help me out on this. Oh and another thing when I burn a CD I can never read in my CD player but only in DVD players. Why is this?
I'm also wanting to upgrade the CD burner, possibly making it a CD/DVD burner is this possible? And wanting to upgrade the sound card and graphics card. The sound card in it right now is a Realtek AC97 which I'm sure is WAY outdated. As far as the graphics card I dont know what it is and I dont have to be a HUGE improvement, just a little. I've got like Doom and old Duke Nukem on here and every now and then I may buy a hunting game or I've got Silent Hill 4:The Room on here. So I mean I'm not a hardcore computer gamer but I would like up to my graphics just a tad bit. Can somebody please help me out?
Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200
Post edited by josh_parsons626 on
It probably has an Athlon XP2400 processor. We need to know what you currently have in it. I'm pretty sure its a socket A motherboard. You would be best off just to upgrade to a gig of ram than change out the processor. Are you burning Mp3s to the cd, or are you converting them to Audio CD's. What program are you using for the burning?
Ben -
System info
Compaq instructions for upgrading the processor
Go to NewEgg and search for a Socket A processor. Do some more research and make sure the mobo bios supports the processor you want. -
PhantomOG wrote:System info
Thats the problem with Compaq's and HP, and many mobo's to be fair. The XP-2400 is a 333 FSB and faster proc's typically have the 400 FSB (barton core) which doesn't work with many of the Compaq boards in that series. Get more RAM.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Hey bud, I think I've got a 256mb compaq ram stick at home I'll give ya for cheap.
Well I figured since I was upgrading all of what I already done it might not hurt to go ahead and upgrade the Processor as well. But if y'all think it's fine then I guess I'll leave it alone. The processor is an
that's what it says under my system information.x86 Family 6 Model 8 Stepping 1 AuthenticAMD ~1998 MhzDon't forget to look at My Home Theater
Subwoofer - Velodyne VRP-1200 -
josh_parsons626 wrote:Well I figured since I was upgrading all of what I already done it might not hurt to go ahead and upgrade the Processor as well. But if y'all think it's fine then I guess I'll leave it alone. The processor is an that's what it says under my system information.
Yep it is a Athlon 2400XP
That is a fine processor if you aren't loading a ton of junk programs at startup. Just do the ram upgrade:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Agreed that that processor will be fine.
Upgrading the CD burner is super easy, just unplug and unscrew the CD burner and plug in the DVD burner. The hardest part is getting your hand in there.
Sound card isn't THAT bad, although you may run into some problems if you don't uninstall the sound drivers before you unplug the old sound card. Ditto for the video card (maybe even moreso - last time I did a video card it effed with things so bad that i had to reinstall XP).
Good luck man.If you will it, dude, it is no dream. -
So as long as I dont have a lot of crap on my startup taskbar then I dont have to upgrade the processor, correct? Just another strip of ram. Should I take out the 128 (stock) and put in another 256 or put in a 512 then later on replace the 256 with a 512 OR would I EVER need that much memory?
OK
If I can find just a DVD burner can I still burn CD's? And what if I wanted to burn movies would I have to upgrade my processor then?Don't forget to look at My Home Theater
You don't need to upgrade your processor. I think my main PC has a 2400+ in it, and I burn movies all the time.
DVD burners are capable of burning CDs, so you will have no problem.If you will it, dude, it is no dream. -
All DVD burners I've seen, also burn CD's. Your cpu speed is fine. I burn DVD's and play the latest games with a slightly lower speed than yours.
Josh, does your mobo have an AGP slot for a video card?
PolkThug wrote:Josh, does your mobo have an AGP slot for a video card?
Um......I have no idea what you said man sorry!!! Don't forget to look at My Home Theater
Total expansion slots Three PCI, AGP4x 1.5v
Available slots Two PCI, AGP4x 1.5v
From the link I posted... -
crap, the extra RAM I've got is only 128MB. If you've got a third RAM slot, I'll mail it to ya for free.
no I've only got 2 slots. But I really do appreciate though. I just wish I did have a 3rd slot LOL that would be awesome. What do you think my plan sounds like? Another thing, where's a good place to shop for computer parts?Don't forget to look at My Home Theater
Hey I found this DVD / CD Burner on newegg. I dont know how to see if it'll work on my computer so I thought y'all might be able to take a look at it and tell me if it'll work.Don't forget to look at My Home Theater
The only line that really matters when seeing if it'll work on your computer is this one :Interface E-IDE/ATAPI
So yes. They're all pretty compatible. As long as it doesn't say "SATA" or "serial ATA" in that space, you're fine.If you will it, dude, it is no dream. -
Damn Bob I have to agree with all 3 post you have wriiten :eek:
I'm getting scared:D
For memory newegg.com + corsair=:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
for memory the timing matter more than the speed when you have a amd processor.
your processor will be fine for almost everything. if you want to rip DVD's i would use "DVD shrink" works great for me.
do you still have your old hard drive? i dont think it is destroyed, just needs to be reformated.
some good memory:
http://www.newegg.com/Product/Product.asp?Item=N82E16820144122
http://www.newegg.com/Product/Product.asp?Item=N82E16820146896Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
Sophie, no I went out and bought a new 180 gig (i think) hard drive.
