SurroundBar with Cantilever Mount?
Hi,
I have a SurroundBar currently sitting on a table top. I plan to move my plasma TV off of a table top to a cantilever wall mount so that the plasma is adjustable. I would like to also move the SurroundBar so that it follows the same angle as the plasma.
Does anyone know of a cantilever mount for a SurroundBar? How about a bracket that mounts the SurroundBar to the bottom of a plasma TV?
Thanks,
Will
Thanks,
Will
Post edited by wfoulds on
The Plasma will not be flush on the wall. It will have a mount that allows it to swing away from the wall. I need roughly a 30 degree angle since the furniture in the room is positioned in an odd way.
I could put the SurroundBar flush on the wall. However, if I did, it won't be aimed at anyone. That's why I would like to have it move with the plasma. -
