sunfire hook up suggestions
BAD ASP
BAD ASP Posts: 361
hey all, I am a newbie to club polk. I have posted a couple of things but you all have influenced me enough to purchase a used sunfire signature 5.1 with the 425 wpc rating. My system starts with the polk 1.2 tl up front. I will be using my Denon 5700 for the pre. This creates my first question. .....
I also have an onkyo which has pre's. My perception is that the denon has better musicality then does the onk. Does using the av as a pre influence the sound reproduction? In other words is it unecessary to use the denon, as the av provides no influence on the sound as the amp is doing that?
Are there any suggestions as to the hook ups? I use the system 65/35 HT over music.
My amp will be going in an entertainment center and will be less than 3 feet from the pre. Is there anything wrong with using monster cable rca patch cords.
Any sunfire users out there who can give me their impressions over their previous av gear. I am hoping for a quantum leap in sound performance, will I be disappointed?
Right now I am using a mid-value Klipsch center. Is there enough of noticeable difference in the sound quality,since it seems to be monaural anyway, between different center channel speakers from quality builders? Would replacing it with the polk LSiC provide a noticeable differnce?
sorry about asking for so much info but I have a lot of catching up to do.
mike
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Post edited by BAD ASP on
  • Tour2ma
    Tour2ma Posts: 10,177
    edited March 2007
    Man, you ask a lot of questions... ;)
    BAD ASP wrote:
    ... purchase a used sunfire signature 5.1 with the 425 wpc rating. My system starts with the polk 1.2 tl up front.
    Congrats on both counts... Slight correction though, your Sunfire is a 5 ch... not 5.1. The ".1" refers to a sub-woofer channel of a Pre-Pro or AVR. It's decoder lingo, not amp terminology...
    Most would agree with your impression, I know I do. But your impression is all that matters. Try both... pick the one you like better... sell the other or use it in a 2nd rig.
    I'd bi-amp your 1.2's using the L and R channels and the 2 surround channels. Pre-outs of AVR go to the L/R ch's, jumper the "spare" RCA for each of these ch's on the Sunfire to a surround channel. Wire the L/R "current" outputs to the tl's upper (tweeter) posts and the Surround ch's "voltage" output (only choice in the surrounds is voltage) to the tl's lower/ bass posts.
    BE SURE to REMOVE THE JUMPERS from the tl's, if you bi-amp per the above.
    As for the center, I bi-wire off of a center ch with the current output to tweeters and voltage to MW's. Again, remove the jumpers on the speaker, if any.
    Let the Denon (or Onk) AVR handle the surround ch's, if any. Surround demands are not that great, especially if you run them set to "small".
    I would suggest using banana posts, single or dual, for the Sunfire speaker connection. Space is kinda tight back there, and you don't want any rogue wire strands bridging ch's.
    Nah... there are better IC's out there than MC's, but they're a start. I use Signal Cable's Balanced IC's, but my Pre-Pro accepts them and your AVR choices may not.
    Do be sure that your ent center is adequately vented. Sunfires run "cool" compared to most amps, but that does not mean that they do not generate heat... they do, especially when you get frisky (and you will), and they are ill equipped to dissapate it.
    Disappointed? No... Furthermore, as a precaution, you may want to grab a pack of Depends next trip to the store...
    I cannot see the Klipsch being a good tonal/ timbre match for the 3000's in your tl's. Bi-wiring the Klipsch will give it it's best chance of blending as the current output of the Sunfire is noticeably smoother.
    Play some music and swap from 2 to 3 ch and back. If the sound changes (other than volume-wise), the match can be improved. If you note a change, try swapping the Sunfire's L/R output to the tl's tweeters from current to voltage, and repeat the test. Making the input to the tl's 3000's a little "edgier" may help the blending of your frontstage, but may make the tl's less listenable in 2 ch duty. You'll have to A-B the tl's as well swapping the amp output to the tweeters.
    If you decide to ditch the Klipsch, an LSiC may be a good choice, as good as there is available. Buy one where you can can try it, but return it if it is not the answer.
    Have fun...
    More later,
    Tour...
    Vox Copuli
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    Hey tour2ma, I've been away on business for a few days so I just read your reply to my epistle. Thanks very much for taking the time to deal with my questions. I will be working on the system this weekend and I will work with all of your suggestions. I have been on the look out for the LSiC center channel to replace the Klipsch. Again thanks for taking the time to answer all my newbie questions.:D
    Rears: Polk LSiFX
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited March 2007
    Mike,
    Welcome to the Polk family!
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    I think there was a GI Joe action figure named BAD ASP.....wait, where am I?
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    hey Doro,
    When i was a kid there weren't any GI joe figures to play with. As a matter of fact, when I was a kid, if you were a boy and played with dolls that was an open invitation to a good **** kicking LOL. Just kidding Doro.
    I took the name bad asp because I have a couple of muscle cars made by ford and they're cobras. And since I believe them to be bad **** I tried a play on words to get through the Illinois DMV. The plate on my 66' shelby cobra replica is bad asp.:D
    Thanks for the welcome guys!
    mike
    Rears: Polk LSiFX
  • dorokusai
    edited March 2007
    LOL....dolls! Their ACTION FIGURES! :D
    Sorry for the derail.....you should post some pics of that Cobra sometime.
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    Hey Doro,
    a couple of pics of the cobra and engine. The specs are:
    2450 lbs
    408 w cu.in.
    93mm intercooled turbo
    tremec viper 6 spd
    on board fire suppression
    etc etc.
    My son's and I built it over a 4 year period.
    Rears: Polk LSiFX
  • dorokusai
    edited March 2007
    That's absolutely beautiful.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    BAD ASP wrote:
    Hey Doro,
    2450 lbs
    408 w cu.in.
    tremec viper 6 spd
    etc etc.
    That is definitely my dream car. Poked and stroked 351w?
    Is it wrong to get a woody when looking at a car like that?
    Oh yeah get rid of the Klipsch center. It is definitely way off with timbre match.
    Welcome to Club Polk
    Ben
    My 2nd choice for any car would be 68-70 Mercury cougar :D
    Ben
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    thanks, this car has been on my wish list since I first saw one in 1966.
    She is poked and stroked as well as timed and tuned specifically to this turbo. It's idle is not as lumpy with the turbo but you get over that pretty quick when you pass through 3500 rpm. The car is a pleasure to drive if you enjoy the smells, sounds, momentary loss of hearing and loading your shorts every once in awhile.
    I look forward to finishing my set up with the sunfire.
    mike
    Rears: Polk LSiFX
    tonyb Posts: 33,069
    edited March 2007
    Hey dude,if that Cobra makes it's way to the FM,I have dibbs.
    That is one of my dream cars,SWEEEET !!!!!
    +1 on the center
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    what's FM?
    I am currently looking for an LSC1c in the auctions. I will definitely swap out the center, thanks.
    Rears: Polk LSiFX
    tonyb Posts: 33,069
    edited March 2007
    Flee market....for sale...Anytime you want to sell that puppy,give me a yell.
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    tonyb, I don't know if I could ever sell that car. Lot's of fun memories with the boys putting it together etc. Plus it really is a lot of fun to drive. I see you live in the chicago area, if you want we can hook up this spring and I promise not to scare ya.;)
    Rears: Polk LSiFX
  • ben62670
    edited March 2007
    Does this go for me too. I would be very tempted to fly out there just for a ride in that car. I have great body function control to:D
    Ben
    tonyb Posts: 33,069
    edited March 2007
    OH Man...That would be awesome!!!!How far from the Algonquin area are ya?
    You just made my day friend......beer and lunch on me.And I am not telling the wife as she will want to sit on my lap for that ride.:D
    tonyb Posts: 33,069
    edited March 2007
    Hey Ben,saw some hot cars down by you,includeing a nice red
    Ferrari spyder.......driven by a punk looking 18 yr old who looked like
    his daddy would buy him another if he scratched it.
    Fly out man,you can stay with me,will get BAD ASP to cruise over
    go for a ride,listen to some tunes,Eat drink and be merry ya know.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited March 2007
    I just want the ninja cat in the pic
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2007
    tonyb,
    I live in park ridge, right by the airport. Thats about 8 minutes by cobra or f-18. I work in Schaumburg and I drive the car to the office when the weather is cooperating. This little beast doesn't like wet tracks too much. :eek:
    Rears: Polk LSiFX
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2007
    welcome to the club mike and as everyone has said, wicked car. And have fun with the system buddy.
