Has Anyone Made a Set of Cables Like This?
Bill Ayotte
I am going to make a set of cables that are RCA/XLR combination. Has anyone else done this before? Any advise? I found a little tutorial at:
http://www.diycable.com/main/product_info.php?products_id=609
I was wondering if there was anything else they left out.....
Post edited by Bill Ayotte on
Those look like quality cables for the money,Canare makes excellent products. Ive used their LS 61 75 ohm as a digital cable.Testing
Testing
Testing -
I'm going to use Cardas Crosslink IC cable with cardas RCAs and Neutrik XLRs. I picked up some techflex and heatshrink as well, I would like these to at least give a somewhat professional appearance. I am kinda anxious to get the stuff and get started.
I found the key to getting them to look good is stripping the wires and insulation the correct amount.I like their idea of adding some hot glue to prevent shorting and add a bit of strain relief.Testing
Testing
Testing -
I thought that was a cool idea too. I am actually going to do that to my wingcord at work too, because that thing keeps breaking the terminations.
These are the two colors of techflex I bought
I had to buy 25ft of each, so if this works out I may determine a price and sell a few pairs. -
They call it superhero......stupid name, but it looks sick
Be sure to post some pic's of your finished cables.Testing
Testing
Testing -
Hi,
I have made a couple of rca ic with the cardas twinlink wire and their GRMO and GRCM rhodium over silver plate rcas. They sound very good. Solid bass crisp top, very quiet. I am using silver wire with eichmann copper rcas now and find the bass is lighter and the top is nice. I go back and forth. I may get more cardas wire to use with the eichmanns. I also use cardas wire in the tonearm of my TT. Hope that helps.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
You bet your as I will.:DGV#27 wrote:Be sure to post some pic's of your finished cables. -
Thats cool. I am hoping that the cables I make will best the Signal Cable Analog IIs I have hooked up now. We will find out next week.
Well, they are done. The biggest challenge was figuring out how to work with techflex. I managed to screw it up about three times on the first cable, of course the second one worked out the first time.
Well they are bueatiful... How do they sound?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
they sound great.....Better than my Signal Analog 2's did anyway.....A lot less hiss coming from the speakers. There was a little bit of a difference in music as well......A little more "open" I guess. I heard a few things in albums I hadn't heard before. The voices in movies were a little bit more clear as well, especially at low volume. I would have been on cloud 9 if they just worked, the result was just awesome
Sweet. I find much more enjoyment when I make things instead of buying them. I have done 4 different IC cables myself, and it is nice that you can try different wire to see what works with your system
Enjoy, nice job
Ben -
Nice work Bill,they look better than some of the mega buck cables.Testing
Testing
Testing -
Thanks man. I am looking for a cheaper supplier for the actual cable so I could maybe make a set or two for some of you guys for a reasonable price...
Nice job Bill.Michael
NORTH of 60° -
Those look very professional...nicely done.
On a side note, I just get the whole magnet wire thing. I tried it and find it to be anything special at all. Maybe a synergy thing?
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
