Help selecting AMP for Polk LSi's - budget around $500.
Nostalgic
Hey all.
I have a pair of LSi15's, an LSiC, and a crap psw100 sub coming. (I'm obviously replacing that sub soon enough). Use will be 80/20 for HT/music.
Anyway, I have an HK 435 receiver that is said to be pretty powerful for an AVR.
But, I do want to get the full potential out of my setup as well as prevent any damage to the speakers/AVR from powering their 4 ohm impedance with an AVR rated at 8 ohms.
Also, I will eventually add some surrounds so I'll have a 5.1 system.
Questions:
1)With a budget of about $500 (give or take a little), what would you recommend for an amp? I think I want at least 200 wpc into 4 ohms from what people are saying but who know. What amp do you recommend?
2)I have a separate cable for my future SVS or HSU amp and will use it from the sub out on my AVR. Do people use amps for their subs too or does the sub itself have it's own capable amp?
3) Will the amp you recommended in the $500 range be enough to make my LSi setup sing or will they not be near their potential with that budget?
Thanks everyone! I'm hoping to get it soon since my speakers will be here tomorrow.
N.
Questions:
N.
Post edited by Nostalgic on
1) For $500, you're not going to find a whole lot if you're looking for it to drive 5 channels. You might be able to find some 3-channel amps for that price... one name that comes to mind would be Adcom (GFA-5503).
2) If your subwoofer has a built-in amplifier (also known as active subwoofers), there would be no need for separate amplifier. You would simply run the sub pre-out.
3) The LSis will sound good. But they will sound BETTER once you get more power. The LSis are a power-hungry line of speakers.
My suggestion, sell the subwoofer and put that money towards a quality amplifier. If your goals are to run 200watts at 8ohms, don't skimp out now. The downtime up front goes by a lot quicker than the downtime halfway down the road when you're already knee-deep in this stuff. Truthfully, it's tough to get enough power for a 5.1 LSi setup with $500... in fact, it's darn near impossible. $750 maybe... -
Welcome Nostalgic. You should be looking at getting 200wpc @ 8ohms which will give you 300 @ 4. The more headroom you have the better.
If you are planning a 5.1 system with all LSI's you should get a 5 channel 200wpc amp, & you won't find any at $500.
So just take your time, save much more money & start looking at the used offerings for multichannel amps on Audiogon so that you can get a rough idea of what they are going for.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I've got 9's, 7's,& C running off a Parasound HCA-855A (discontinued) 125w@4 Ohm x 5.
Works fine for me and the price was about half your budget(used off Ebay).
GHT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
You could use a Parasound Halo A23 which is rated for 2x 125w @ 8 ohm, 2 x 200w @ 4 ohm. A sweet sounding amp which I think is a plus for LSi speakers.
You could find one used on Gon for around $500.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Hell, get an Adcom 555 for the 15's and leave the LSiC on the HK. It should be fine pushing just the center, especially if you set it to small. Save up for a more serious 5 channel amp or just keep on adding 555's. Three Adcoms will have two power supplies more (and one channel more) than your typical 5x 200 amp and you can do a lot worse.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Emotiva is having a sale on 7 channel amps for 500 clams with free shipping ,
Here is the link.
http://www.emotiva.com/lpa1.htmlMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
I was really interested in the lpa-1. However, I have read posts by several people stating that the lpa-1 will not offer much if any difference than my HK 435 AVR.
Any thoughts? -
I highly doubt it ,that amp has real balls and plenty of power to spare for the price and I can guarentee you that it has plenty of juice for your speakers and it won't wimp out like the H/K will.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
try it...Nostalgic wrote:I was really interested in the lpa-1. However, I have read posts by several people stating that the lpa-1 will not offer much if any difference than my HK 435 AVR.
Any thoughts?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote:try it...
I know that's the best way. But, the free trial may not include shipping this beast back to them. Just want some more insight from you experienced guys.
For $500, you can't really go wrong. I'm with Ron and Lou, give it a try.
This is the most important thing that you have pointed out!
It's easy for these guys to say try it, they won't be out the shipping costs or have the aggravation of having to return it if you are not satisfied! Then the additional expense & aggravation of getting what you should have gotten the first time around!
I'm a firm believer in doing it right the first time Nostalgic. It is much better to have more than you need, rather than find out the hard way that you should have gotten more after the fact.
You won't have to doubt having more power, which can be used through all future upgrades over the years.
Unless you are one of those people who like to endlessly try new gear just to see the difference it makes, do yourself a favor & go for the gold the first time around.:)Nostalgic wrote:I know that's the best way. But, the free trial may not include shipping this beast back to them. Just want some more insight from you experienced guys.
Pick up an Aragon 2004 for the 15's and thank me later.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I counted 268 amps I thought would work for you, then my boss said I have to quit wasting my time, I told him this is not wasting time, it's important, it is audio, it is passion, he disagreed.
OK, buy something with high current, I suggest paying more than you can really afford, you will be happier in the end. Broke but happier and misery does love company.
RT1
Edit: OOOOOoooooo, Russ that is a great idea, I should get an Aragon, great amp, so then I will have an A-Aragon and B-Balanced Audio, how about C, what should I get for C, man I will end up with 26 amps this way, effin awesome idea, the Alphabet Rig is Born. I am gong to need a bigger Shed. Christ just realized I already have two B's--B&K and Balanced Audio, should I get another A so I am balanced, naw........it will be like baseball cards just have doubles of some. -
Ted, reach for the Decaf next time
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Ted...
If that stupid letter "Y" can't even figure out whether it's a consonant or a vowel, how the hell do you expect it to maintain the integrity of a pure signal.
Garbage in, garbage outI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
just to offer a different perspective...
i dont think much of putting alot of effort into the rear channels, even for HT. concentrate on getting a nice 2/3 channel amp (lots of good recommendations above) for your front and center speakers and use the HK for the rears. that should allow you to get something very nice for the front soundstage and still stay within your budget. again, this is just my opinion... -
You can get Adcom GFA-555's all the time for $350 off ebay. There are about 12 on there right now. I have one and it puts out 200@8ohms, and 325@4ohms.
kinda a no brainer if you ask me.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
"Y" get a nice Yamaha amp. Maybe something mid-80's for your sda's (like an M-85)zombie boy 2000 wrote:Ted...
Ted "C" - Carey Audio they should have at least a few amps that sound decent...
The alphabet rig, sounds like a killer Idea for polkfest.
H for Halo
P for Parasound
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I was going to say the same. Got one from Russ and it's a great match for my 15's.RuSsMaN wrote:Pick up an Aragon 2004 for the 15's and thank me later. -
Y is for YBA.
Yamaha, that's funny!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
ooohhhhhhhhh, I likey YBA, nice, unique, good looking stuff, I could work backwards from Z........man this is going to cost big big bucks, I may have to pan-handle in front of Winn-Dixie with my monkey.....
let me see a Z, not an easy one, Zu makes some nice speakers, don't know about amps....
sorry for the highjack but these amps being thrown around are ones you might consider, well, at least know about as the budget may not allow. -
My system is similar to what unc2701 suggested. I'm running my Lsi7's off of an Adcom 545 and the rest of my system off of my H/K7300. For me, I don't notice a difference good or bad in the sound, but my AVR runs much cooler now. I'm not offering this up as saying it's the way you should go, just thought I'd concur that this is an option for you. On that note, I think you'd probably want the Adcom 555 that unc mentioned...don't think you'd be satisfied powering the LSi15's with the 545.Things work out best for those who make the best of the way things work out.-John Wooden
Well I run Halo A23 amps for my L / R with my Onk driving the center and rear surrounds. I can say I noticed a difference
night to day, day to Halo, night to Onk.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Look for a used Rotel 1075, audiogon.com and specs at the Rotel website. You can get one used for ~$700 in grat condition.
I checked audiogon.com and the few Rotel 1075's they have are sold. It is 120 W x 5 channels at 8 ohms. Or get big brother the 1095 at 200 W x 5 at 8 ohms. This will cost you more like $1,000 to $1,200 used.
You'd actually be pretty luck to find a 1095 for $1000-1200. They seem to go for more around $1500.
Here's my current "Watching" list on eBay for amps. I'm not going to bid on any of them... just like to keep them handy for situations like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=007&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=170084710108&rd=1&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=220087332971&ssPageName=STRK:MEWA:IT&ih=012
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150095555558&ssPageName=STRK:MEWA:IT&ih=005
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=290088226795&ssPageName=STRK:MEWA:IT&ih=019
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130083712937&ssPageName=STRK:MEWA:IT&ih=003
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=250085129937&ssPageName=STRK:MEWA:IT&ih=015 -
dane_peterson wrote:You'd actually be pretty luck to find a 1095 for $1000-1200. They seem to go for more around $1500.
I have 4 of those same amp on my watch list
Hey here's a question.....alright we already know an Adcom is a damn good cheap amp. What about a damn good cheap pre/pro? What would be some suggestions? And while I'm asking questions is it better to use your DVD player to listen to CD's or a dedicated CD player?Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200
