bi-amp RT 55i
mr9iron
Hello all,
sent this to Polk customer service, thought I would post here to see if I could find any help at this forum:
I want to horizontal Bi-amp Polk rt 55i speakers. The manual says they can be bi-amped this way, however, the top posts only send signal to the tweeter, there is no mid range. The bottom posts send signal to both the 6 in drivers. I did not expect this. I would think the designers at Polk would have used the top post for high and mid and the bottom post for the low stuff using the bottom 6 in driver. Apparently they are not set up this way.
My objective is to use my tube amp for the high and mid range, and a solid state amp for the "punchy" low stuff. Obviously these speakers are designed the way they are for a certain reason, but I think there is no real "bi-amp" capability with the way these are right now even though the manual says they are. I do not think using a dedicated amp to just drive a tweeter is what Polk intended for bi-amping.
I would really appreciate any information or insight on this, I can respond with more specifics if you need more information than this.
thank you so much,
Jeff
thank you so much,
Jeff
Post edited by mr9iron on
These speakers were not designed for heavy bass.
Bi-amp top for tweeter and bottom for the two "mid" drivers.
It's just that simple. Got the equipment give it a shot. Need more bass - buy a good sub. Good Luck! -
Scott thanks for your reply,
I am not sure what you are feeding your Polks or if you have the model confused, but the RT 55i has plenty of bass, enough to hit the mid section anyway. I do use a sub for really low stuff, I was referring more to the "punchy" bass like kick drums than I am the thunderous low bass.
I don't think I would just use my tubes to drive two tweeters, that is not very good use of the resource, not to mention the liquid mids you will miss with the tubes. I will just leave the entire thing hooked up to the solid state if I can't get this to work.
Mind you, I am not trying to get more bass out of the speakers, in fact nothing could be further, I just prefer tube high and mid, the most typical reason for Horiz - bi-amping.
Thanks anyway,
Jeff -
Jeff,
I see what you are driving at and think it's a stellar idea. However, with the 55's (and most biwireable speakers that I can think of) it's just not the way they are designed.
BDTI plan for the future. - F1Nut
