under power bad??
mirra540ryder
ive heard that its bad to under power a sub i have two mm2154 getting around 100 watts they supose to get 400 but its like i dont turn it up loud right???
Post edited by mirra540ryder on
Underpowering a speaker doesnt harm it at all. The reason underpowering is associated with blown speakers is that when you use too small an amp for a certain speaker, it wont perform at its optimum and you wont get as much output out of it. So to compensate you crank up the volume or worse, the gain. This increases the chance that youll push the amp into clipping, which sends out a whopper of a powerful signal at 2-3 times the rated power of the amp and limited only by its input voltage. Its this overpowering that kills the speaker.
Still, if youre only using 100 watts into a 400 speaker, even at full distorted clip I doubt it could generate enough power to kill that sub. Now if you were using say a 250 watt amp, then it could potentially fry the 2154 with a clipped signal.
Either way, its best to properly power a speaker and if youre not, then its best to play safe and keep the gains and volume kinda on the low side.polkaudio sound quality competitor since 2005
yea i never have turned the head unit past half way with the bass boost up all the way and the amps are temp im hoping to get a kenwood or a profile amp soon or maybe one for each sub what ever is cheaper
You never want to put the bass boost up all the way. For every 3db of boost in a particular frequency, you are asking you amp to double its power in that frequency...... not many amps on the market have that kind of head room when being played at higher listening levels. Adjusting your gains properly is the best thing to do.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
but if i was clipping then wouldnt that make my sub distort and make it sound like it was inside a trash bag:eek:
also my box is bigger than its supose to be what kinda bass does that take away?? my highs or my lows
