SDA 1-C troubles
opsman35
opsman35 Posts: 5
edited February 2007 in Vintage Speakers
Hello all,
I have a pair of SDA 1-C's. It appears that the stereo drivers on the Left speaker are not functioning. I have checked the wiring to make sure it is correct, additionaly if I move the Stereo drivers from the left speaker to the right they function properly. I feel that I might have a problem with my crossover. I pulled it out and the soldering is very sloppy. I think the previous owner attempted to fix the same problem, but instead made a big mess. Any ideas on the best approach to get these functioning properly again? I had a set of SDA's previously and miss them a great deal! Any help would be appreciated.
Post edited by opsman35 on
  • ben62670
    ben62670 Posts: 15,969
    Welcome to Club Polk OPS.
    I would take a multi meter and check the resistance from point to point on the crossover. The stereo drivers should not be affected by bad components as far as being able to play. There is a small inductor in series with the positive lead from the speaker terminal that should have slight resistance. Try also measuring from the positive input terminal to the black wire that connects to the stereo drivers. There should be a small amount of resistance between these 2 points.
    Ben
    Ben
  • opsman35
    opsman35 Posts: 5
    Thanks Ben. I will give that a try. Can you tell me where to go from there? In other words, if I do or don't see the resistance you have described.
    Thanks,
    Brian
  • schwarcw
    schwarcw Posts: 7,358
    Hi ops! Welcome to the Club Polk Forums! Any chance you could get a closeup picture of the crossover and post it in these threads.
    Also, I assume that you have the interconnect cable and a non common ground amp. What kind of amp do you have?
    Keep posting, we'll help you!:)
    Carl
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Welcome to CP!
    Let me know if I can be of any help, I own a pair of 1Cs and am in Enid every Tuesday and Thursday.............
    Dennis
  • opsman35
    opsman35 Posts: 5
    Thanks Guys. Yes I do have the interconnect cable, my amp is a Carver M-200 t. The phase speakers are working fine on both sides. I only have the problem with the Left channel stereo section. Dennis, just curios what in the world are you in Enid for twice a week if you don't mind me asking? We are a little secluded out here.
  • opsman35
    opsman35 Posts: 5
    Carl,
    Yes I will try and post a picture this week.
  • Dennis Gardner
    I call on many of the band/music programs in the schools in your area with my business out of Woodward.
    F1nut Posts: 51,700
    Post both sides of the crossover.
