Anyone have an electronic version of the Jolida JD 100 manual?
jrlouie
I was just wondering if anyone had an electronic version of the manual for the JD 100 that they could send me. If so, please send me a private message and I'll give you an email address to send it to.
Thanks in advance,
jrlouie
Thanks in advance,
jrlouie
Post edited by jrlouie on
Call Jolida, they will send you a copy.Political Correctness'.........defined
President of Club Polk -
Jolida is sometimes a bit slow to respond. If you don't have any luck with them, I'll see if I can get my scanner to work and send you mine. There isn't a whole lot in there thouh, that isn't obvious.
Jeremy...check your email...it will be in 2 separate emails hopefully. I scanned them as .jpgs so they're kinda big.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
dragon,
thanks a million dude. got the emails. i looked at a couple of the jpeg's, they seem good to go. i owe ya one.
