2 mm124's
Systems
im looking into two mm124's. i am wondering how these will do in a ported box. if they work well in ported box's could you send me plans of an example? thanks
Testing
Testing
Testing
Testing
Testing
well, you'd be hard pressed to find anyone who will endorse a momo in a vented enclosure... and the polk reps themself will tell you they dont reccomend it at all. they push sealed or bandpassed -- most anyone else will harp on sealed for the momo.The Artist formerly known as PoweredByDodge
the answer is no on ported, trust me. u will be replacing the sub if u do
