Anyone have an electronic version of the Jolida JD 100 manual?
jrlouie
jrlouie Posts: 462
edited February 2007 in Electronics
I was just wondering if anyone had an electronic version of the manual for the JD 100 that they could send me. If so, please send me a private message and I'll give you an email address to send it to.
Thanks in advance,
jrlouie
Post edited by jrlouie on
    F1nut Posts: 51,698
    Call Jolida, they will send you a copy.
  • pblanc
    pblanc Posts: 261
    Jolida is sometimes a bit slow to respond. If you don't have any luck with them, I'll see if I can get my scanner to work and send you mine. There isn't a whole lot in there thouh, that isn't obvious.
  • dragon1952
    dragon1952 Posts: 4,907
    Jeremy...check your email...it will be in 2 separate emails hopefully. I scanned them as .jpgs so they're kinda big.
  • jrlouie
    jrlouie Posts: 462
    dragon,
    thanks a million dude. got the emails. i looked at a couple of the jpeg's, they seem good to go. i owe ya one.
