I need help BI-AMPING my 1.2 TL's
Deadof_knight
Deadof_knight Posts: 980
:mad: OK here it is at the moment its running off my tfm-35 sounds great , I have a Yamaha mx-830 I wanted to use on the top end and Bi amp these babies. I tried this once and them simply hooked up my tfm again.
Problems upon power up I inserted a cd and the sound was way weird I think it could be the poitive negative reverse ,I believe the dimentional driver were not playing correctly...
I also know they are slightly different in power ratings The mx is way under rated IMHO. butt........
Anyone got some suggestions or the same problems at one time or another with a fix
:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
Post edited by Deadof_knight on
  • george daniel
    george daniel Posts: 12,096
    edited February 2007
    not to be a smartass,but you did remove the jumpers? I bi-amped a pair of 2.3 with and adcom/carver tfm 45 combination once, did not experience any issues,, adcom r&l to the r&l low inputs on the 2.3's and the carver r&l to the r&L "mid/highs",,
  • danger boy
    danger boy Posts: 15,722
    you said it already sounds great running off the TFM-35.. so why do you want to bi-amp them ? :confused:
    PolkFest 2012, who's going>?
  • joeparaski
    joeparaski Posts: 1,865
    If he had not removed those jumpers, his post would have read much differently, more along the lines of "I blew up my amp". (speaking from experience).
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    tonyb Posts: 33,069
    Kind of wondering that myself.........since the top end doesn't
    require that much juice anyway.Given the amp you want to try it with,I gather to say you won't hear a big difference.Now throw alittle tube
    action up there and then we have something.
  • george daniel
    Joe
    You Serious? :eek:
  • Deadof_knight
    I was simply wanting to run more power, The jumpers come on guys Im a fairly intelligent guy, Im going to pick up my other tfm-35 in a day or two I had tried the yamaha and it sounded like I mighta had left right mixed up or maybe the positive negative reversed but + on + is what the amp shows , Just might have thought yamaha's were bassakwards or something.
    The yamaha is a very clean sounding amp If I do say though. Not a tube I know but we gots what we gots. They both sound fine when hooked up seperatly. but together it sounded like the dimentional drivers were ,I dunno how to decribe it really any body got a quote out of the Darque's commendum about trouble shooting and bi-amping?
  • joeparaski
    Of course you're a smart guy, after all, you bought a beautiful pair of speakers.:D
    In my situation, I FORGOT to remove the jumpers (I had just bi-amped my 2.3 tl's and simply forgot when I did the SRS). I had a 350 wpc Phase Linear for the lows and a 200 wpc SAE for the highs. As soon as the power came on, the SAE went up in smoke and caught fire! After a few tense moments I put the fire out....and learned an expensive lesson....."take your time and look things over carefully before turning on the power". I was darned lucky that I didn't fry the Phase Linear or the SRS.
    Joe
  • Deadof_knight
    Holy "SMOKES" ................OUCH that had to hurt ! OK joe after you successfully bi-amped how did it sound better or worse if thats possible ?
  • joeparaski
    I'd have to say it sounded better. And therein lies the problem with this hobby. I change something, for example, I added an external DAC, and heard an improvement. But later, as the ears adjust I assume, the system sounds like **** again, until another change is made. Does it ever end? (never mind, I know the answer to that one).
    I'm at a point now that I am addressing all the little details. I'm sending every amplifier one by one to the shop to get bench tested as well as replacing the power cords, binding posts and RCA connectors.
    joe
