Speaker Decoupling Tweak
Early B.
Bought two butcher blocks from Marshall's ($14.99 ea.) to set undernearth my floorstanding speakers. The butcher blocks are 14" x 14" x 1.75" and have feet on them. Works great! They raise the speakers 2.5" off the carpeted floor.
My speakers were resting directly on the floor, no spikes (per manufacturer's instructions). My goal was to minimize the vibrations the bass was sending to the floor and to tighten up the bass a bit. I planned to purchase a pair of Auralex Subdudes ($49.95 ea.) for this purpose, but decided to use these butcher blocks instead.
The bass sounds like it's not on the floor anymore, if that makes any sense at all. Bass notes are a a little tighter. The butcher blocks also reduced the rattling of the flue in my fireplace during deep bass passages.
Got some more listening to do, but so far I'm pleased with the results.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Here's a pic...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Interesting... I use spikes even though my speakers are on a hardwood floor. My results pretty much fall in line with yours. Bass is tighter and I find that imaging improves (though this may be due to the fact that the tweeters are closer to ear level). If anything, it certainly reduced cabinet resonances.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
I tried spikes on the bottom of the boards, but for some reason they didn't make the boards more sturdy. And I certainly wasn't going to add spikes directly to the speakers. They'd be too heavy to re-position with spikes on them. Besides, I like the extra height on the speakers that the boards offer.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Glad to hear this helped. Have you thought of trying concrete sidewalk blocks under the speakers? They come in assorted styles and colors and have more mass than butcher blocks.
I have placed some gray tinted blocks under my subs as they do not have spikes.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
jm1 wrote:Glad to hear this helped. Have you thought of trying concrete sidewalk blocks under the speakers? They come in assorted styles and colors and have more mass than butcher blocks.
I've used concrete slabs for subs with good results. I used wood in this instance for the aesthetic value. The slabs, even when painted black, have a DIY appearance.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
If nothing else we know what you are cookin' tonight!
I sooooo want a pair of vmps towers like you have!
Do you here that?......sounds like envy to me!
:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
Wow, just now saw this thread - didn't know you were the one to start this trend. I've had great success with the Auralex Gramma, which is exactly the same as the "Subdude" with a different label. I wish I'd done this tweak as soon as I got my big Legacy Sig IIIs. I need to spend more time in this forum!
Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
I got a piece of granite from a countertop place and it worked great. Just ask for the cutouts from a double sink and they will practically give it to you. (you can have them poish the edge for you, but that will cost)
Looks nice, is heavy as hell, and works great for my SVS.
I glue and stack these under all my components. Cheap, great isolation (vulcanized rubber) and almost invisible.
$1 each
$1 each again
