Denon DVD player
jflail2
With some very sound advice from you CP members, I was able to invest in the beginnings of a nice new HT setup yesterday. I still have a free Valentines Day gift of my choice between 100-200$, so I was curious which Denon DVD player I should pick up to fill the void.
I think I'd like one of these 2 models as I don't want to spend a ton with HD formats finally getting into the realm of reason.......:
http://www.crutchfield.com/S-KOgsaAC0dBh/cgi-bin/ProdView.asp?g=54400&I=033DV1730B
or:
http://www.crutchfield.com/S-KOgsaAC0dBh/cgi-bin/ProdView.asp?g=54400&I=033DV1930C
Not sure if I see that much of a difference here, so I wanted to see if any of you had good input either way.
Thanks!
or:
Thanks!
Post edited by jflail2 on
The 1930 plays SACD and DVD-A.
I would also look at the Oppo 981hd. Probably the best "bang for the buck" out there. If you have DVI or HDMI.
But Denon is no sloutch either. If set on Denon I would go with the 1930. IMOMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
What type of display are you using. Between these two I would go with the 1930 as it has Faroudja DCDi de-interlacer. The oppo player 981 HD is also a very good player and is well under your budget.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I've got a sony xbr 910 34" CRT. I haven't looked into the Oppo yet, but this might be the opportune time. I was going to keep my components Denon for the time being, but if this Oppo is the real deal then I might just save some $$....
edit: The sony has a DVI input, but no HDMI (which sux.)2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
You can easily convert between DVI and HDMI using a simple adaptor so DVI input on your sony will work fine.-izafar
Get the oppo 970-HD which is what I have ,the denon has the Faroudja DCDi de-interlacer which is notorius for mackroblocking on plasma and crt tvs ,as for dvi you can get the adapter for it to go to hdmi at the link below.
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10419&style=My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Wow, that 970 definitely looks like the best buy at $149. All the reviews sound great; looks like another solid recommendation.
I guess I can convert to DVI and then run my audio via optical?
Thanks for the help, this has turned into a nice upgrade.2007 Club Polk Football Pool Champ
Yes you can convert to DVI and run the optical or digital coxial out for dvds cds it also has analog outputs for SACD/DVDA I own the 970HD myself and love it. It may not have the same sleek looks that the denon has, but it performs very well. There has been several of us here at CP that have got one of the various oppos. Do a search here if you want to get a few more oppinions. Denon has always made quality players but its hard to beat the oppos at this price range. REGARDS SNOWjflail2 wrote:Wow, that 970 definitely looks like the best buy at $149. All the reviews sound great; looks like another solid recommendation.
Thanks for the help, this has turned into a nice upgrade.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
oppo 981, and youre golden, plus its future proofShoot the jumper.....................BALLIN.............!!!!!
Oppo..
Sherardp wrote:oppo 981, and youre golden, plus its future proof
I second that...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Denon 1930"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
I was looking at the 981 last night, but I was worried about this:
DCDi by Faroudja
which Lou had mentioned earlier as being notorious for macroblocking on CRT's.......Any other CRT owners have any feedback regarding this dcdi??2007 Club Polk Football Pool Champ
Denon generally "gets it right" when it comes to DVD players. They may not be the current "be all...end all" player, but chances are they will be around for a while."Just because youre offended doesnt mean youre right." - Ricky Gervais
I have the Sony 34" XS955 HD CRT, which uses the very same tube as your set. I've used the Denon 2910 and 3910 - macroblocking hasn't been an issue for me (and I'm really picky). Furthermore, I've noticed that this TV looks best with a good 480p digital output from DVD players. I didn't like the effect of 1080i/720p upscaling - looks too soft on this set - so I wouldn't make that a deciding factor in player selection.jflail2 wrote:which Lou had mentioned earlier as being notorious for macroblocking on CRT's.......Any other CRT owners have any feedback regarding this dcdi??
You could look for a Denon 2910 used on audiogon - sometimes they go for $350 or less. HDMI video from the 2910 into your set will be as good as it gets, period. Audio quality is also excellent.
For cheap, the Panasonic RP-91 can sometimes be found for a song used. It's component video outputs are still great, and audio quality is super. Its deinterlacer is weak and won't work well with poorly mastered stuff like anime, though.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
I went from a Denon 1910, to the Oppo981. The Oppo beat the Denon hands down. And if your worried about the Faroudja chip, I believe both players have the same chip, but IMO, Oppo does a better job with it.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I say just go for the oppo, that thing does everything minus blu-ray/HD DVD playback. Save ya self the coin also, put it on something else you want, a few movies, a good quality cable, and be done.Shoot the jumper.....................BALLIN.............!!!!!
After much debate, I pulled the trigger on an Oppo 970HD today. I would like to have had the 981 1080p version, but I figure I'll pick up one of those when I get a display that has 1080p capabilities as well. That, and the 970 gave me the option of using HDMI or component, whereas the 981 only offered HDMI out.
Anyone know much about the usb and card reader? Any caveats I should know about?
I'm stoked; this is the last piece of the puzzle for the time being. And as Sherard said, I definitely saved some coin. $149 was a steal in my book.2007 Club Polk Football Pool Champ
