SDA-1's
jpiii
jpiii Posts: 4
edited December 2002 in Speakers
Hello All,
I own a couple of pairs of small Polks, newer models, that I love.
My father in law just GAVE me a pair of mint SDA-1's!!!
What would be a good, reasonably priced amp to drive these, bearing in mind, I don't have a bunch of cash to drop at this moment. Appreciate all comments.
Thanks,
Jack in ATL
Post edited by jpiii on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Are you looking for an integrated, a pre/amp combo, what?
    Just a few brands, without getting into specific models, most Carver, Adcom, Nad, Yamaha, Marantz, AMC will work fine, and still be what I consider 'affordable'.
    Lucky dog, btw.
    Cheers,
    Russ
  • RuSsMaN
    Agreed on Rotel, I KNEW I forgot something.
  • jpiii
    jpiii Posts: 4
    I was thinking pre-amp, amp setup. Usually makes for a cleaner sounding system, correct. I am planning on running it 2 ch. stereo only. Comments....
    Thanks gents, I appreciate the help.
    Jack
  • RuSsMaN
    How about a ballpark budget, and we can start linkin' ya up.
  • jpiii
    jpiii Posts: 4
    I was thinking between $500 and $1000.
    Thanks,
    Jack
  • abmarsh
    abmarsh Posts: 109
    The Yamaha RX-V1300 at $799 would be a good choice. The SDAs are reasonably efficient (I have SDA-2As), but, nonetheless, seem to prefer a lot of clean power. At 100 W/channel, the Yamaha would drive them fine and I think you'd find it to be a great sounding system. If I'm not mistaken, the SDA-1s were rated a little more efficient than the SDA-2s.
    I'm driving my SDAs with the RX-V2300. They sound great and will put out absolutely ludicrous amounts of volume.
  • jpiii
    jpiii Posts: 4
    Would a GFA-555 be a good amp to drive them??
    What would be considered a good price for one on EBay nowadays??
    What would be the right pre-amp to pair with that amp??
    Thanks for your help gentlemen!!
    Jack
  • hoosier21
    hoosier21 Posts: 4,408
    DargueKnight is selling a pair of his 555's on Ebay right now, he is a Polk Forum Member. He has a BIN of 450.00 and that is in the middle of the range, I would guess 400.00-500.00 depending on condition. This guy takes care of his stuff.
    Oh yea, it would be a good amp for your 1C's. Talk to him about the combo, he has SDA's.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Adam K. Binder
    Adam K. Binder Posts: 1
    I,ve been using a NAD 730 to push a pair of SDA-1s that I have had since 12/83 and it does a very fine job. Also a NAD 515 CD changer. I still play my LPs though. Good Luck, Adam
