XLR cables?
I am looking to move to XLR balanced cabling. Has anyone had any experience with the different brands that are out there? It seems they start at around $200 and go up from there. Let me know how big of a difference they made in your system.
Thanks,
Jer
Thanks,
Jer
"The only way to get rid of a temptation is to yield to it."
Post edited by jrausch on
Jer,
How's your RTA 11TL, whats your plan for it.
BTW, Congrats... -
Never bought any 11TL's. I bought a Parasound P/LD 2000 with Balanced inputs and outputs. I'm looking for any kind of word as to what brand of XLR balanced cables to buy."The only way to get rid of a temptation is to yield to it."
I use monster XLR cable. crystal clear sound. not cheap but u want the best for your amp right?!My Setup
panasonic 50" plasma
Monster Power 7000 SS
Silicon Image IscanUltra Pro
B&K reference 50 preamp
B&K reference 200.7 amp
Martin Logan Ascent i main
Martin Logan Theater i center
Martin Logan Decent Sub
Polk RT 800 for side surrounds
Polk FX300 for Rears -
My friend works at a dealership and can get them for half price @$100 a pair. Is there really a differance between the monster and others that run 500-750?"The only way to get rid of a temptation is to yield to it."
