Small LCD for OSD?
camtah
camtah Posts: 128
edited February 2007 in DIY, Mods & Tweaks
I am toying with the idea of adding a small TFT LCD for the OSD on my Outlaw
990. Anyone done this? I am looking for some design (mounting) ideas in my home theater.
Post edited by camtah on
  • Lsi9
    Lsi9 Posts: 616
    Nice Idea, have you thought of perhaps keeping it closer to your seating position rather than near the rack? that way you can turn it on or off depending on when you need it. Curious what options are there? is there any models below 15" and what are the prices?
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • scottvamp
    scottvamp Posts: 3,277
    A must have for front projection systems. I done some research but have not pulled the trigger yet. I wanted to use a flat panel computer monitor but it used a different type of DVI. I have not found a simple adapter. I could get away with a simple s-video plug.
  • camtah
    camtah Posts: 128
    Yes, I have a projector and it is a pain to switch back from HDMI to composite and trying
    to use the AVIA disk. I was looking at a portable DVD player. My HT has a bar at the back with A/V and PC hook-ups. I am looking at a 6-8 inch TFT LCD
    Any recommendations?
