Realistic Mach Ones
Bonfrisco
Bonfrisco Posts: 17
edited February 2007 in Speakers
I own a pair of Mach Ones. I was asked by someone if they were liquid cooled. Are they? If so how can i tell if they are liquid cooled?
Are there two kinds of mach ones? (Liquid Cooled and Not liquid cooled)
THANKS..
Post edited by Bonfrisco on
  • Mjr7531
    Mjr7531 Posts: 856
    edited June 2005
    Do you mean if the tweeter is ferrofluid cooled or not? I highly doubt they would offer two versions if it's in an actual speaker.
  • deezyok
    deezyok Posts: 1
    For all your information, Yes there was 2 different pairs of mach 1s for those of who who are not sure what these speakers were there is one way to check and see if you have the good set, cat 4024 and cat 4029 if they are liquid cooled and have 6 screws on the face plate youhave the garbage pair, if you can beleive it, if you have non liquid cooled with ten screws on that same faceplate you have the good pair, Todays price made Brand new $1500 Each, your welcome
  • hoosier21
    hoosier21 Posts: 4,415
    Damn
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
