Question about Fuse install
howie777
howie777 Posts: 357
edited February 2007 in Car Audio & Electronics
I can't seem to find a good place to mount my new fuse holder under my hood. Does anyone know of a good adhesive that is rated for the engine compartment that would work (I think it needs to be 120 C)? Or is this not recommended? This would allow more options for me.
I'm thinking of mounting it on the side of my fuse box and I don't want to use screws there.
I seem to have a lot of plastic parts and not very many metal places that would be well suited.
Howie
Post edited by howie777 on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited January 2007
    I stuck my Fuses tot he air box with industrial strength double sided tape. Been on there for while now with no problems.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited January 2007
    zip ties:D
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2007
    Yup. Wire ties are perfect for this application. Theyll let you slap it on just about anywhere.
  • Joelsbass
    Joelsbass Posts: 637
    exalted512 wrote:
    zip ties:D
    -Cody
    I third that sentiment, they also work great for keeping your wiring in place as it runs around the engine compartment... probably have a dozen of them in mine (long run from the battery to the firewall)
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
