SVS trouble
toddco
toddco Posts: 147
I have a brand new PC PLUS 16-46 runing on the preout's on my ES sony receiver. When turning the sub up to feal good auto-gun fire like in {We where solders} and they drop a bomb the sub cant take it and cracks, bottoming out, it just cant handle the peakes on a lot of thing. My room is verry small so i know its not that.This thing should kick **** but i'm kicken myself know. Any thought:confused: :mad:
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS
Post edited by toddco on
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2007
    You need to calibrate your system with an SPL meter.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Any chance it is the AVR that is clipping, not the sub? i.e. the AVR is sending a distorted signal to the subwoofer.
    Go into the setup on your AVR and verify that the channel for the subwoofer is set to 0 or less. Just a thought - you are correct, it should be knocking your socks off. If that does not work give SVS a call tomorrow - I am sure they will set you straight.
    Michael
    (to test - you might set your AVR to sub = off and plug your sub into the pre-out for one of your front channels just to see what happens.)
  • dkg999
    dkg999 Posts: 5,647
    edited January 2007
    Try using the LFE out on your receiver, not the R/L pre-outs. This way any bass management controls on the receiver will work for you. I have the 20-39 PC+, and if it's cracking then you are overdriving it somehow. Start with the gain on the SVS at about 1/4 of the way up. Check your sub settings in the receiver and make sure they are at 0, and ideally around -5. Then start calibrating. Once calibrated, make sure you have tight socks on and all the pictures are firmly mounted on the walls :D
    DKG999
  • toddco
    toddco Posts: 147
    edited January 2007
    Have a spl meter and used it with disc from svs and sub is pluged into pre-out
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • Meeks32
    Meeks32 Posts: 330
    edited January 2007
    Make sure you have your subsonic filter on the correct setting on the sub also. If you dont have any ports plugged then it should be on the "16hz" setting.
  • toddco
    toddco Posts: 147
    edited January 2007
    I have tryed no pluges and one plug with the amp set for each. Same problem
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • tecmo04
    tecmo04 Posts: 421
    edited January 2007
    i too have a sony es receiver and a 20-39 pc plus hooked up through the preouts. No problems here. Do you have another sub to try the amp with? Maybe try an A/B test with 2 subs to see if its the sub or amp. But it sounds like its the sub so id call svs...
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2007
    Calibrate! Sub into "sub out". Set to small. What is your sub out set to? It should be to atleast 0 or below. Your sub gain should be no more than 50%.
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    what do you have the volume knob on the back of the SVS set to? do you have it cranked beyond 12 o'clock? if so.. turn it down to 10 or 11 o"clock. if it bottoms out even on low volumes. then you got other problems.
    call SVS in that case then.
    good luck.
    PolkFest 2012, who's going>?
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    That SVS is a good sub but if you run it too hard it will chuff and bottom out. I used to have one of their cylinder subs and that is why I upgraded. I second the calibration for yours just to make sure.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Schwingding
    Schwingding Posts: 363
    edited January 2007
    One cannot simply put in place an SVS sub and turn the volume up on it and expect trouble/problem free operation. Proper calibration is an absolute requirement, as I have learned. In addition, proper room placement can have a HUGE effect on bass. With sub frequencies, the ROOM is the sub enclosure.
    Search around for proper sub placement techniques. With large subs, this is tough, but one way is to place the sub in your listening location, and crawl around the room listening for the spot where bass is most pleasing to you. Put your sub there.
    Both of my subs are properly calibrated and the gains on them are barely 1/4 way up - but there's enough bass to energize the concrete floor. If I turned them up to 1/2, they would bottom out when given tough tasks.
    Why then do they make amps with extra gain? Because all rooms are different.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • toddco
    toddco Posts: 147
    edited January 2007
    All is calibrated, is in the left- right pre-out,never go past 11 o'clock on the gain.Guess i need dual pb12+2, A?
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • toddco
    toddco Posts: 147
    edited January 2007
    I have had this on a second receiver diffrent room same problem
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • jm1
    jm1 Posts: 618
    edited January 2007
    Can you elaborate on why you are using the L+R pre outputs on the receiver for the subwoofer. Do you have the LFE turned off and the front L+R set to full range (should default to this I believe)? Are you aware of there is a difference between the signal content of the LFE and L+R pre outs?
    As others have suggested, use the LFE output to the sub. Adjusting the 'subwoofer' output level on the SSP (receiver) will have no effect when you connect the sub using the pre outs.
    Am I missing something here?
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2007
    Call / Email SVS.
  • toddco
    toddco Posts: 147
    edited January 2007
    Yes, no ajust effect with the pre-out being used. Using the pre-outs because polk says its the only way to go if you want to do it right. LFE out same problem.
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Where do you have the gain control set on the back of the sub? (like about 11:00 or less?) What is your sub channel set to in the AVR? (provided you are using your LFE out on your AVR) Do you have the sub end of the cable plugged into the unfiltered or lfe in on your sub?
    Set up like this (just for testing and to humor us):
    in AVR - set sub to on, set all other speakers to small (80hz crossover), set sub channel (the speaker balance part) to 0.
    hook sub cable from LFE out on your AVR to LFE in on your sub.
    turn sub amp to 10:00-11:00 position.
    Play movie of your choice and let us know what happens.
    Michael
  • MattN03
    MattN03 Posts: 558
    edited January 2007
    Call or email SVS. Their tech support is fantastic (just like Polk)! :D
  • danger boy
    edited January 2007
    honestly, i find it VERY difficult to bottom out an SVS if everything is set up properly.. unless of course. something went bad in transit to your place.
    I know other Polkies have bottomed out their SVS's before.. but I never have.. and like i said earlier. it's very difficult to do, not impossible, just not easy.
    so toddco, what else can you tell us about your AVR settings? in the menu is the sub volume set to 0 ? are you running two pre out RCA cables to your sub? If so.. unplug one and only use one from your pre out.
    At what volume does it bottom out? Buying a larger SVS may help.. but it still doesn't account for what you are saying that your current sub is bottoming out.
    Maybe the amp is shorted out or something.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2007
    Do not use the L or R repout, use the Sub pre-out. You're sending a full range signal not the LFE. Use the SVS setup tips not Polk.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • scottvamp
    edited January 2007
    Yep, that is what the sub-out/lfe is for.
  • danger boy
    edited January 2007
    he says he's tried the LFE output as well with same results.
  • toddco
    toddco Posts: 147
    edited January 2007
    Yes full signal that is Y the amp has a crossover and is being used with one cable. I know SVS subs are at the top of the food chane and i will be happy once i get this handeled. I went SVS because of this forum and others. you guys know what your talking about and i'm lissnen
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
  • scottvamp
    edited January 2007
    So is SVS sending another one?????? You say it's defective and that is the simple solution.
  • scottvamp
    edited January 2007
    Ya, OK!!!!:cool:
  • toddco
    toddco Posts: 147
    edited January 2007
    where working on IT. THANKS:eek: :cool:
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
