denon avr-787
phra8lao
hi, i have denon avr-787 and just bought rm6750. what is the best option for this receiver and speaker set? should i connect the sub by what polk recommend or should i connect using the pre-out subwoofer rca jack on the receiver ? I just want to make sure i have the best setting. thanks in advance for the advice.
I would think that Polk would recommend you plug the sub into the SUB jack on your receiver. What does Polk recommend?
phra8lao wrote:or should i connect using the pre-out subwoofer rca jack on the receiver ? I just want to make sure i have the best setting. thanks in advance for the advice.
I always recommend using the LFE out on the receiver. It is your best option for bass managment IMO."Just because youre offended doesnt mean youre right." - Ricky Gervais
