CSW200 In-Ceiling Install
Walker1
I am getting ready to install two CSW200 Subs into my newly completed home. It will be an in-ceiling installation of both, as my house is on a slab. The room is a 20x17 room with 11 ft ceilings. I have currently installed, over the months of building, 2- LC265is as Main R & L and 1- TC265i as the Center and 4 LC80is as the L & R - Rear Surrounds in the ceiling. I have the placement figured out for the subs but my issue with the CSW200s are how to neatly put them in the ceilings. I have some new in the box, very cheap round 5 ¼ in wall speakers that I actually took the speakers out just to use the frames with the easily locking cams and grills they are almost an exact match of the grilles to the LC80is that are currently in the ceiling.
As bass is non-directional will the small openings of these 5 ¼ in wall frames be sufficient? I would love to just have 2 frames and grilles of any of the LC/TC/RC 80i series speakers for the perfect match but cannot and will not justify dismantling such a pricey speaker . I already have two A/C vents located in the ceiling near the potential install sites so I do not want to put up more return A/C type vents. Any thoughts?
Post edited by Walker1 on
Well guys I know I am a Polkie but I figured someone would reply. No matter, I enjoy reading all of your various posts and as an avid DIY-er - I figured it out myself. The long process of designing and personally installing my HT as building a new house is complete. With the above referenced issue I questioned, I decided to go with a pair of cheap Pyle Driver 8" In-wall speakers that I picked up off ebay for about $13. These were almost an exact match (from the outside) to the LC80i's I had already installed in the ceiling. Well, after a wife/kid free day in the attic, several trips up and down a 11ft ladder, and a lot of making sure that there would be NO rattles - it is complete!!!
I wanted a completely in-wall HT setup with the same sound I have been accustomed to with the all of sounding furniture that has been in my previous residents. I tall order but the Polk CSW200 in-walls can and did provide! The 2 CSW200 with matching SWA500 (very lightweight) amp can shake a concrete foundation if necessary I am very impressed. Below are some pics of the sub installs and I hope to post some system pics soon. Any questions about the install of these 50lb monster, I will be happy to answer. -
Nice work!
I am curious about the timbre match of the TC265 with the LC series? -
Dave - I am, by no means, an acoustic PhD but do I have two good ears. Objectively, I believe the TC265is as my center setup complement the LCs robust LS-ish sound. I think another LC would be overkill (but just financially) in a center channel configuration. The TC is more than adequate in reproducing clean, clear voices as well reproducing the beefy lows and crystal clear highs of that channel.
Walker1 wrote:Dave - I am, by no means, an acoustic PhD but do I have two good ears. Objectively, I believe the TC265is as my center setup complement the LCs robust LS-ish sound. I think another LC would be overkill (but just financially) in a center channel configuration. The TC is more than adequate in reproducing clean, clear voices as well reproducing the beefy lows and crystal clear highs of that channel.
Thanks, I asked because I will eventually transition from my TC265's to LCs and wanted some feel for how that would sound when blended. I also really like the built-ins for HT. -
I do not think you will be dissappointed.
System Install Updated - Finally
http://www.polkaudio.com/forums/showcase/view.php?userid=75733 -
I'll be the first to complement you on your complete setup. NICE WORK! Clean,Neat and yes you need a bigger screen. LoL. Good job and welcome to the Polk family.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
