Another Pre-amp Suggestion thread
Lowell_M
Lowell_M Posts: 1,660
edited January 2007 in 2 Channel Audio
I did some searching and didn't really find what I wanted... here's where I am at...
I am still planning what I want to do for a 2-channel system in my living room. I want to get some more listening time with the LSi9's, but so far what I am thinking is LSi9's, an ADCOM amp (545 or 555) and a pre-amp, which is undetermined.
I talked with H9 briefly about pre-amps and want to get some other thoughts thrown in.... I don't have a budget to give you because I don't really have an understanding of what you get for your money in a pre-amp. I want something entrylevel that isn't going to cause me to save my milk money for a year, but has great sound for the $. My only frame of reference for Pre-amps is a quick listen of a nakamichi and an Audcom 110 tube-pre. I absolutely loved the Audcom.
So, is that enough info to get some suggestions?:confused:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • Lowell_M
    edited January 2007
    Source will be a CD player of some sort.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    heiney9 Posts: 25,513
    edited January 2007
    Hopefully on our next get together DKG999 will bring the Audcom along to demo again. Tubes and LSi's don't always go hand in hand because the LSi's can be a bit laid back. That being said perhaps a tube pre w/ a solid state amp and Lsi's would be a good match.
    I believe DKG and I were talking about Jan 27 or 28. When you get back home check your calendar and see if that works for you. What is your time frame on putting this 2-ch system together?
    Also part of what you heard was what the DAC was presenting as well as the LSi's. We haven't really talked about a DAC yet, but I'll let you hear the system w/ and w/o. But we can discuss that in person. I'll do some thinking, but as I mentioned to you when you were here the only Adcom pre worth anything is the GFP-750 and used they still run $600-750.
  • george daniel
    george daniel Posts: 12,096
    edited January 2007
    FWIW, an adcom pre (750)was just listed for 730.00 on AC.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    I have an old Yamaha c-85 (purchased by me in the late 80's) It was a good pre in its time. (early solid state - parametric eq, no remote (model before remotes came out for the pre's)
    If you want to borrow it for awhile, you are welcome to. You can bring it back during chicagofest (late June).
    It is currently not being used. Not for sale, but you are welcome to use it for comparison or just to get you by till you get something else if you want....
    Michael
  • Lowell_M
    edited January 2007
    Michael
    Michael, Thanks! I may take you up on that if I put everything else together first. I'm not in a hurry right now. It will probably be a few months before I start snagging things off the flea market and the gon. May even be after the chicago-fest, but we will see. I've been too busy to enjoy the rig that I have. (I tend to plan way ahead to make sure I understand what I really want, of course, this depends on the get together with H9, since after our first listening session I made an impulse buy on my ADCOM amp and haven't second guessed it a bit)
    H9, I have to check with my social coordinator when I get home, but right now I can't think of any reason the 27th or 28th wouldn't work.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Music Joe
    Music Joe Posts: 459
    edited January 2007
    How about a passive design? Interconnects under 2 meters?
    See if you can get a passive on loan.
    If your brave you could try the "Bolero test".
    http://www.high-endaudio.com/RC-Linestages.html#BOLERO
  • dkg999
    dkg999 Posts: 5,647
    edited January 2007
    Aaron - I've also got a couple of like new Parasound P/HP-850 pre's setting in the spare gear closet. One of the best cheap SS pre's out there. I'll bring it to our next get together. Doug.
    DKG999
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    I second that, I'm using one right now. Sounds very nice for the cash, especially if you don't care about remote controls.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • Lowell_M
    edited January 2007
    Doug, You must have a big closet, dude. The only extra crap I have in my closet are a couple gym bags and yahtzee. You've got the coolest (and seemingly endless) spare gear stash.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • dkg999
    dkg999 Posts: 5,647
    edited January 2007
    Once you get past the audio gear in my closet, it gets really, really, scary :eek:
    Actually, my audio gear stash is about 20% of what it was 3 years ago! After 35 years in this hobby, I might of actually figured out what I like! Well, at least I'm getting closer ;)
    DKG999
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2007
    I will also 2nd that,a very good low $ pre...
  • phipiper10
    phipiper10 Posts: 961
    edited January 2007
    If I can just jump in here, I see a couple of postives for the parasound php 850. This is on my short list of preamps I'm hoping to obtain shortly.
    Another option I was considering was Channel Islands Audio VPC-1. I realize this is passive vs the parasound. In either case it would be my first experience with an actual preamp separated from my receiver, so in either case it's really an experiment. My CDP puts out 2.2v so I think this should be fine if I went this route. As you can tell I'm trying get a reasonable preamp relatively little money.
    Any other thoughts/ warnings regarding either of these? I'm open to other suggestions and have been watching ebay for all sorts of preamps from NAD carver, hafler etc...
    Thanks for any additional thoughts.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • del44
    del44 Posts: 686
    edited January 2007
    Have you considered Rotel? The RC-1070 sells for about $350-$400 used. I believe it has a remote also. The RC-1090 can be had for about $600 or $700. Pretty good bang for the buck.
  • phipiper10
    edited January 2007
    I'm not ruling anything out except money ;) . The two I mentioned can be had for less than $150. I'm really only in a situation (due to WAF) where I can just get a teaser of a preamp.
    Later this year or when polk releases their new speaker line up will hopefully upgrade possibly to LSis when everyone here dumps theirs for the new stuff.
    HAH!
    Will revisit the rotel's which is where I started but what I had seen didn't necessarily impress for the money. Used stuff is a little tougher to audition....so I'm willing to just give stuff a try.
    Thanks!
    billbillw Posts: 7,800
    edited January 2007
    If remote control is not important, the B&K Pro10 MC is often mentioned as being one of the better <$500 preamps. It has passive or active feature, and a pretty good phono stage if you ever decide to get into vinyl. The external power supply is rare in its price range.
