witch remote to buy
goingganzo
i am looking and was going to buy a Logitech Harmony 890 newfrom amazon for $250 or Universal Remote Controls MX-3000 $544
is the mx worht the extra or will i be happy with the logictech with has rf and a ir blaster so i can use it out of sight?
Post edited by goingganzo on
I think you should be ok with the Harmony...I love my 659.
Damn......$544 for a remote....hope it brings you a beer when you're thirsty
love my 880!
the 890 is normaley 399 and the mx 3000 is normaley 999
880 and 890 are the same thing except for the IR transmitter which i didn't need. You'll love it. Try it out.
I would wait to see what the capabilities and price of Sideshow enabled remotes will be http://www.engadget.com/2007/01/09/hands-on-with-a-bunch-of-sideshow-remotes/God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Sideshow remote? No thanks, no need for a remote that does anymore than control my gear. The computer is in the next room if I need those abilities, and it has much bigger screens.
I think it depends on what you will ultimately be using the remote for. I have the 890, and am happy with it for controlling the HT. I think it also has the capability of controlling some household items (lights, etc), but I don't use it this way yet.
However, if you want a remote to control lights, window shades, ceiling fans, etc...you would probably want to step it up a notch to the MX-3000. It looks like that one is really designed for a custom "whole-house" install, and you would already know the answer if that is what you are looking for.
EDIT: To answer the second part of your question, I previously had the 880 and returned it, specifically because of the concerns that you have regarding line-of-site issues. With the 890, I have no problems. -
thanks i think i will go for the 890 i also am running my hmdi cable to my lcd in the bedroom so i can do dual room sorce and with the 100 feet i can cancle 1 hd cable box this will be sweet. i wonder if i can use my ps3 controller to from my room
The customer service from Harmony(Logitech) is second to none. I had a small issue with my 659 and the CS rep spent a ton of time on the phone with me trying various timings (Had to have the STB turn on last and there is no option on the 659 for turn on sequence) We basically spent 45 minutes adjusting the timing and refreshing the remote. Excellent service from a really caring CS rep.Yamaha RX-V1500
Pioneer Elite DV-46AV
Scientific Atalana 8300 PVR-HD
Panasonic TH-42PX60U
Polk RTi10
Polk CSi5
Polk F/Xi3
Polk PSW 350
Mike's IC's
DIY speaker cables (Kimber 4VS Shotgunned) -
I have the 890 and I like it a lot. Just don't put the remote in the cradle after turning your system on until the screen shows ready or it will freeze up. Just a little something I learned.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
after installing a mx-3000 all i can tell you is Wow, this remote does it all. you can create what ever background, images for buttons etc... It does any type of electronic, lights, shades, recievers, projectors etc.... Kind of a big remote but my customer likes it much better than the 880 he had. i have yet to use an 880 but the 3000 is very sweet. if you can get the 3000 for 544 that is around cost if not below on it.Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18 -
Harmony Remote easy to set up. I have 2 an 880 & 688 both work great no problemsBedroom Stuff 5.1
Pioneer Elite VSX-82TXS
Pioneer Elite Blue Ray BDP-05FD
Monster Power HTS3500
Harmont Remote 880
Sony Bravia KDL40S2400
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Martin Logan Abyss Sub:D
::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite DVD DV48AV
Pioneer Elite 910HD
Monster Power HTS3600
Harmony Remote 688
Warfedale Diamond 8.4 Front
Warfedale Diamond 8.2 Sides & Rear
Warfedale Diamond 8 Center
SVS PB12-Plus/2 Sub:D:D
My wife & I have been very happy with our 880. She said it was the best purchase I made for the H/T system...lol
wint for the mx and the rf/if extender
http://www.newegg.com/Product/Product.asp?Item=N82E16880100616
http://www.newegg.com/Product/Product.asp?Item=N82E16880100614
