long interconnects
Aaron
Aaron Posts: 1,853
edited October 2001 in Technical/Setup
Does anyone have a recommendation for a cheap interconnect that's 15-20' long? The only cheap ones I saw were Scosche cables at Parts Express. They have one in the $13 range that looks OK. Anyone have any experience with these or any other brands? Also, does anyone know a source for inexpensive MIT Terminator 6 cables? Thanks.
Aaron
Post edited by Aaron on
  • kmasaryk
    kmasaryk Posts: 4
    edited October 2001
    www.avcable.com has some good deals. I'm not sure how good the quality is though since I'm really not sure what makes a 'good' interconnect cable.
    I'm trying to find a 30'-40' interconnect for my PSW350 sub. avcable.com has a 50' cable for $36.00. A nice price but I'm guessing that the quality is crap for that price.
    Anyone know of any other good sites for buying cables?
    kevin
  • PETERNG
    PETERNG Posts: 915
    edited October 2001
    I had one, very heavy duty not sure how long but very long..., I will check when I get back in town. Let me know if you interest...
  • Aaron
    Aaron Posts: 1,853
    edited October 2001
    Yeah, I'm interested. Let me know what you have and how long it is. Man, that just didn't sound right! :eek:
    Aaron
  • PETERNG
    PETERNG Posts: 915
    edited October 2001
    The cable is 20ft long, look exactly like MC cable but made by SOLUTION, RCA style, gold plate contacts, thick and heavy contruction, color coded.
  • Aaron
    Aaron Posts: 1,853
    edited October 2001
    Is this cable supposed to be anything special, or just a nice, inexpensive interconnect? How much do you want for it?
    Aaron
  • PETERNG
    PETERNG Posts: 915
    edited October 2001
    I have no use for it right now, If you need it, I will mail it to you (so you can check out the quality of the cable), if you decide to keep it, send me a check for $12. If you decide not to keep it , please mail it back to me (sound fair?). Please post your email address...Thanx...:)
  • Aaron
    Aaron Posts: 1,853
    edited October 2001
    Sounds fair. I'll take it. You can get my email from my profile, but I'll save you the time and tell you it's ASherrick@aol.com. Also, do you have any decent, inexpensive speaker wire (like Monster XP) laying around? I need two 10' runs. Thanks.
    Aaron
  • PETERNG
    PETERNG Posts: 915
    edited October 2001
    The cable and a pair of MC XP (6ft) are on their way to you...:cool:
