Question about amps
doug lang
I have a question comparing two amps for output.I purchased a nad 2200pe 2 channel 100 amp listed at 100w. I am using the amp for two side speakers to complete 7.1 with my Sunfire. The add on speakers are Cambridge s300 multipole 8 ohms, rated at 10 to 100 watts. The problem is I really can't hear them to clearly. I have made adjustments with all remaining speakers, but still they are very quiet.
First would a bigger amp help say 200 watts, or do you think the speakers are to lame for my system. Thanks
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
Did you listen to those speakers in 2 channel stereo through the NAD? If they sound fine in two channel it's more likely you might have been expecting more than is delivered in the surround modes.
It really all depends on the movie. Most sounds out of the side/ rear channels are more subtle than one might expect, at least in my experience. At virtually no point would you find them as dominant as say a center channel.
Again my experience. Don't get me wrong those surround speakers make a big difference in the middle of a movie but just wasn't what I initially expected. Maybe the same is true for you?Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Have you calibrated the speakers using an SPL Meter ? ...
If not that's a good place to start ... -
Yea i could be expecting two much from them. They are definately not as strong as my rears (FX's). Those i can hear.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
You know i still don't have a meter. It's lame but i still do it by ear.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
One final question, Would a bigger 2 channel amp give you more responce.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
interesting problem. i have no idea what the speakers should sound like on your system. but usally more information is given to the sides versus rear surrounds. so i assume in most cases you would hear more from the sides. unless of course your rears are say rated at 104 db at 1 watt and your sides are rated at 87 db at 1 watt for example then you would never catch up no matter how big the amp. i would try to go into the menu on you pre pro and adjust the levels there if possible. and i would buy a sound meter to try to balance things out. of course a bigger amp usally sounds better. but your nad should have plenty of power for most speakers. they normally have a very high amount of headroom and a good amount of gain. REGARDS SNOWdoug lang wrote:I have a question comparing two amps for output.I purchased a nad 2200pe 2 channel 100 amp listed at 100w. I am using the amp for two side speakers to complete 7.1 with my Sunfire. The add on speakers are Cambridge s300 multipole 8 ohms, rated at 10 to 100 watts. The problem is I really can't hear them to clearly. I have made adjustments with all remaining speakers, but still they are very quiet.
First would a bigger amp help say 200 watts, or do you think the speakers are to lame for my system. ThanksWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
doug lang wrote:You know i still don't have a meter. It's lame but i still do it by ear.
When you are talking about HT sound, you cannot rely on your ears to calibrate your system. You need to purchase a DVD like AVIA (or rent it from Blockbuster) and purchase or borrow a Radioshack SPL meter. Using the white noise testtones from the AVIA DvD you can accurately calibrate your system.
This will tell you several things to include:
1) That your system is set-up correctly and that all speakers are functioning
2) That your system has ample amplification to drive all the speakers to reference level.
3) Whether you have timbre matching speakers to give you a smooth transition
etc...
By doing this you ensure all speakers are playing at the same loudness and that you do not have a speaker or set of speakers set too hot. From the above test you can determine whether you need more amplification, speakers are set up right (i.e. are in phase and timbre matching), and where to start to improve your system.
In other words, sometimes it is not so wise to trust your ears.
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I would not think changing the amp would do anything; if they are calibrated correctly, this would offset any amps difference between the different speakers.
Agree that you should hear more from the sides than the rears; have you tried all channel stereo? Or Changing the feed at the Sunfire to swap rears with sides to see if the "low" speakers are still the same?_________________________________________________
Sounds like a gain and efficiency difference. You will really need to calibrate the whole system. More power won't play louder if it isn'e calibrated.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Get a RS SPL meter & calibrate. You can use the test tones that come with the receiver. Put the speakers on the Sunfire, I will bet you will hear a difference, I certainly did. And if you do, you now know why I recommend 200wpc for all speakers. If you don't then I would say that the speakers just don't have it in them once they are fed more power & properly calibrated.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I am familiar with the NAD power envelopes, its overkill for a surround speaker, plenty of juice there. Just calibrate as suggested, with different brand amps you are likely to have different slew rates which has to do with how fast the amp is, lots of people mix amps and its not generally listed as a problem, as suggested your speaks likely have different sensitivety.
RT1 -
Hey thanks. I recalibrated the speakers, and moved the sides a little closer to ear level. You know one problem i have is a tight room with some loud speakers. As you can see by my system all polk 4 ohms. They like to be driven.
I will also be getting a meter, i have been told this by all a number of times. By the way i just watched twister and it really sounds great. Some of you have said 7.1 is worth it, i have to agree. Thanks again and best to all, dougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
