witch remote to buy
goingganzo
goingganzo Posts: 2,793
edited January 2007 in Electronics
i am looking and was going to buy a Logitech Harmony 890 newfrom amazon for $250 or Universal Remote Controls MX-3000 $544
is the mx worht the extra or will i be happy with the logictech with has rf and a ir blaster so i can use it out of sight?
Post edited by goingganzo on
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2007
    I think you should be ok with the Harmony...I love my 659.
    Damn......$544 for a remote....hope it brings you a beer when you're thirsty :)
    SOPA
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2007
  • goingganzo
    edited January 2007
    the 890 is normaley 399 and the mx 3000 is normaley 999
  • BaggedLancer
    edited January 2007
    880 and 890 are the same thing except for the IR transmitter which i didn't need. You'll love it. Try it out.
  • ledhed
    ledhed Posts: 1,088
    edited January 2007
    I would wait to see what the capabilities and price of Sideshow enabled remotes will be http://www.engadget.com/2007/01/09/hands-on-with-a-bunch-of-sideshow-remotes/
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2007
    Sideshow remote? No thanks, no need for a remote that does anymore than control my gear. The computer is in the next room if I need those abilities, and it has much bigger screens.
  • szhleppy
    szhleppy Posts: 325
    edited January 2007
    I think it depends on what you will ultimately be using the remote for. I have the 890, and am happy with it for controlling the HT. I think it also has the capability of controlling some household items (lights, etc), but I don't use it this way yet.
    However, if you want a remote to control lights, window shades, ceiling fans, etc...you would probably want to step it up a notch to the MX-3000. It looks like that one is really designed for a custom "whole-house" install, and you would already know the answer if that is what you are looking for.
    EDIT: To answer the second part of your question, I previously had the 880 and returned it, specifically because of the concerns that you have regarding line-of-site issues. With the 890, I have no problems.
  • goingganzo
    edited January 2007
    thanks i think i will go for the 890 i also am running my hmdi cable to my lcd in the bedroom so i can do dual room sorce and with the 100 feet i can cancle 1 hd cable box this will be sweet. i wonder if i can use my ps3 controller to from my room
  • IanD
    IanD Posts: 59
    edited January 2007
    The customer service from Harmony(Logitech) is second to none. I had a small issue with my 659 and the CS rep spent a ton of time on the phone with me trying various timings (Had to have the STB turn on last and there is no option on the 659 for turn on sequence) We basically spent 45 minutes adjusting the timing and refreshing the remote. Excellent service from a really caring CS rep.
    Yamaha RX-V1500
    Pioneer Elite DV-46AV
    Scientific Atalana 8300 PVR-HD
    Panasonic TH-42PX60U
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
    DIY speaker cables (Kimber 4VS Shotgunned)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    I have the 890 and I like it a lot. Just don't put the remote in the cradle after turning your system on until the screen shows ready or it will freeze up. Just a little something I learned.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • jeremie
    jeremie Posts: 246
    edited January 2007
    after installing a mx-3000 all i can tell you is Wow, this remote does it all. you can create what ever background, images for buttons etc... It does any type of electronic, lights, shades, recievers, projectors etc.... Kind of a big remote but my customer likes it much better than the 880 he had. i have yet to use an 880 but the 3000 is very sweet. if you can get the 3000 for 544 that is around cost if not below on it.
    Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
    LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
  • harold280z
    harold280z Posts: 72
    edited January 2007
    Harmony Remote easy to set up. I have 2 an 880 & 688 both work great no problems
    Bedroom Stuff 5.1
    Pioneer Elite VSX-82TXS
    Pioneer Elite Blue Ray BDP-05FD
    Monster Power HTS3500
    Harmont Remote 880
    Sony Bravia KDL40S2400
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Martin Logan Abyss Sub:D :D ::D
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite DVD DV48AV
    Pioneer Elite 910HD
    Monster Power HTS3600
    Harmony Remote 688
    Warfedale Diamond 8.4 Front
    Warfedale Diamond 8.2 Sides & Rear
    Warfedale Diamond 8 Center
    SVS PB12-Plus/2 Sub:D:D :D
  • MattN03
    MattN03 Posts: 558
    edited January 2007
    My wife & I have been very happy with our 880. She said it was the best purchase I made for the H/T system...lol
