Basic Amp or Receiver help
stardrek
stardrek Posts: 13
edited January 2007 in 2 Channel Audio
Dear Polksters,
I’ve been buying Polk speakers for about 8 or 9 years now and have loved every pair. I’ve recently bought a set of LSi 9’s and was geared up to buy a great amplifier to complement them. Things have changed unfortunately, and the money that was to be used for the receiver has gone to a local hospital.
As a result I’m looking to fill the gap for the next 6 months with a cheap stereo amp or receiver. My budget is small, only $150, but will to go up to $200 if justifiable. I’m hoping you guys can help me out. I have no problem buying used.
This will mainly be used for TV/movies, but also some music DVDs. Any help would be greatly appreciated.
(Should this be in the Electronics section? Sorry If it should.)
Post edited by stardrek on
    edited January 2007
    Clarify please....are you looking for a stand alone 2 channel amp or a receiver?
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    What are you currently powering the 9's with?
    "God grooves with tubes."
  • stardrek
    stardrek Posts: 13
    edited January 2007
    A receiver is actually what I need.
    They are currently running on a Technics SX-GX710, a very respectable receiver 15 years ago. Though this is not an option because it is the receiver to power the RTi6's for my computer. I need a different receiver, I doubt I can find one that nearly as good as the Technics for $150-$200, for a different room.
  • ledhed
    ledhed Posts: 1,088
    edited January 2007
    Look at the HK 3480 or Denon DRA-685 i believe they are around 100WPC and can be had for less than $200
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • stardrek
    stardrek Posts: 13
    edited January 2007
    Thanks, those both look like good choices.
