Will an HK745 power a 7.1 Lsi system
Chris Lyon
Will it do okay for now or will I have to get an amp.
Post edited by Chris Lyon on
First,a hearty welcome.2nd,you are posting in the wrong spot.
If you have done a search,there is a search button,you would find that answer very quickly.But to cut you some slack,the answer to your question is no.Will it turn on and play?Yep.You will be stressing your receiver to the point of possible damage to it and the speakers.Most will tell you to get a seperate amp for the LSI series since they are 4 ohm speakers that need a good 200 watt/channel amp to sound there best.Good luck buddy boy.:)HT SYSTEM-
lsi 9's -
Welcome Chris.
+100 on what Tony said!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
FYI, the HK is more than capable of handling a 4 ohm load.
With that said, I would still look into getting a seperate high-current amp for at least the front stage."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
lots of receivers can handle a 4 ohm load,but at 7-channels of 4 0hm,you are really stressing your AVR.HT SYSTEM-
