Hum Eliminator
Early B.
Has anyone tried this product yet?
http://www.audioadvisor.com/prodinfo.asp?number=EBHUMX
It's supposed to get rid of ground loop hums and other nuisances without **** with the signal. The product can be puchased for $59 elsewhere all over the net.
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Not familiar w/that one, but I have the Mondial Magic ($99) and it's great--- it also doesn't degrade your TV picture.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
steveinaz wrote:Not familiar w/that one, but I have the Mondial Magic ($99) and it's great--- it also doesn't degrade your TV picture.
Where did you buy the Mondial Magic from? -
Umm...that was a long time ago...I think I ordered from the Klipsch website, or possibly AudioAdvisor.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I'm about 99% certain that hum-x is just a GFCI outlet with the ground lifted. Basically it's a UL-approved, safe cheater plug. Save yourself some money and get a good GFCI outlet and just don't hook up the ground wire.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Got the MAGIC hooked up today and I must say it made a hufe difference. It virtually eliminated any hum. Only if I put my ear up the speaker do I hear it.
The down side is that you can't use it to split off to your computer. My cable modem wouldn't pick up the ethernet signal so I had put the CATV splitter back in the path then use a jumper to add the MAGIC.
WesLink: http://polkarmy.com/forums
Ok, not trying to hijack this thread....but.... I have a related situation regarding hum.
I just hooked up the cdp and the receivers preouts into the passive preamp. I get a hum ONLY when both sets of inputs are in and the CDP and receiver are on. This is with both pieces on but idle or during music playback as well. In both cases hum increases with volume.
The hum is not exclusive to the corresponding input. When playing music in input 1 or two I can also hear very faint music/hum if I switch to the opposing input. Is this "crosstalk"? Should "some" be expected or is something wrong here?
So neither piece produces it when they are the only input put the CDP (or some set of circumstances including the cdp create this hum) when the two are inputted at once.
What do you guys think, is something wrong with this preamp?
Thanks,
RichAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Is the system connected to the television or any video device?phipiper10 wrote:Ok, not trying to hijack this thread....but.... I have a related situation regarding hum.
Thanks,
Rich
If so, unplug your cable line from the wall and voila.
Get an EMI/RFI filtering power strip (i.e. Monster Clean Power) that has a cable filtering section and it will pass the signal without the ground problem.
