polk audio monitor 70's
98thumpin wrote:well i know how to bi wire now, do you know what the monitor 70's can handle continiously can they handle 200 rms
would it be safe to drive these with 200 wpc rms clean power?John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
Not only is it safe, but they are going to be Rockin'. The specs for these speakers indicate a max of 275 watts.
ok thats awesome another question? polk audio uses a 8ohm speaker impedence, i was considering buying a onkyo TX-SR804 7.1 channel reciever but i found out the speaker impedence is only 6 ohms or 4 ohms can this run a set of monitor 40 bookshelfs and a monitor series center channel, or should i go with the rotel rsx-1067 surround sound a/v receiver which is rated at 8 ohmsJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
polk audio uses a 8ohm speaker impedence, i was considering buying a onkyo TX-SR804 7.1 channel reciever but i found out the speaker impedence is only 6 ohms or 4 ohms can this run a set of monitor 40 bookshelfs and a monitor series center channel, or should i go with the rotel rsx-1067 surround sound a/v receiver which is rated at 8 ohms?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
i need to know this can a reciever with the impedenace of 4 and 6 ohms drive a set of 8 ohm speakers?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
I think you're looking at it from the wrong angle..
An amp rated to drive 4 Ohm speaks can also drive speakers rated at 6 Ohms and 8 Ohms.
An amp or reciever rated to drive 8 Ohm speaks should only be used with 8 Ohm speakers.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
which would be the better setup?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Don't sweat the ohms stuff. Your Onkyo 804 will have no problem driving Polk speakers.
in someones opinion which is a better reciever the onkyo 804 or the rotel rsx 1067?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Rotel
what makes the rotel the better choice?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
If you are still looking for an amp, look at a carver M400t or M1.0t. They are both 200w rms a channel at 8 ohms.
ok im probably going to go with a rotel ampJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
but im still looking for a high quality dvd/cd playerJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
I really like Outlaw Audio. They have great customer support, great equipment, and best of all great prices. Might be worth your time to check them out. This is an internet only based company, but you can return anything you dont like within 30 days of receiving the equipment. So, dont let that stray you away from them.
http://www.outlawaudio.com/index.html
Good luck. -
TennesseeOutlaw wrote:I really like Outlaw Audio. They have great customer support, great equipment, and best of all great prices. Might be worth your time to check them out. This is an internet only based company, but you can return anything you dont like within 30 days of receiving the equipment. So, dont let that stray you away from them.
Good luck.
This would be for a Pre/pro and amplifiers only.. They do make a great bass management system as well.. I think that may be in conjuction with SMS. -
yeah i saw there bass managment system looked good to meJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
anybody know if the monitor 70s would sound terrible matched with a cs300 and R15? I know, different lines, drivers and tweeters, but how bad would it be?
im not sure i dont have that expertiseJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
There dont seem to be many mon70 fans around. But i am/was. I needed something to put into my HT that would fit two bills.
One would be for HT for movies, the other which is my staple of enjoyment when it comes to entertainment are concerts on DVD. I auditioned the rti and monitor lines. If it came down to simply movies, i would of chose the rti's and not thought about it again. But as you will read here many people feel the rti's are a bit bright for music, and i came to the same conclusion.
The monitors were a bit more laid back to my ears, but still retained the detail i was looking for. Now they arent the perfect speakers for everything, but for my purposes i couldnt find better for the cost.
Ive recently sold my mon70's and upgraded to a pair of 2.3tl's. To be honest, im missing my 70's. Not that i prefer them over the 2.3's but just that they to me sounded great and really didnt leave me wanting. My only regret was selling them. Kinda wish i had just thrown em in the closet for a bit until i found another use for em.
But with that said, im obviously a fan. If you purchase a pair i would advise getting a decent amp to push em with. For reasons unknown to me i liked em better on my lil ole 545 than i do the 555's, so it would be easy to stay within a budget if you choose to.
One last thing, i initially ran them off an Integra DTR 7 which if you dont know is Onkyo. They sounded great. Its a funny mix Onkyo and Polk, they really seem to compliment eachother well. But enough of my blabbing, if you have any questions about the 70's let me know and ill relay my thoughts.
DaveOnce again we meet at last. -
I believe the Monitor 70's are grossly underrated...I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
i agree thats why im getting them i heard them and they sounded awesomeJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
and at a price thats hard to beatJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
i finally decided on a system, monitor 70's for the fronts, monitor 40 bookshelfs for the rear, a cs2 for the center, all bi wired of course, a rotel reciever, and 2 channel power amp from rotel a monstor power power station to suppley the juice and for equipment protection, thinking about a oppo dvd/cd playerJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
does anyone know anything about the monster power power station, is it worth the 600 dollars its cost'sJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
if anyone can tell me anything about this piece of equipment id appreciate it and if you think it is worth the price?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
different schools of thought. I have a monster HTS 3600 (bought it used for less than 200.00 I dont know if it made a sonic difference, since I hooked it up while changing amplification and whatnot
I will say I like having all my stuff going through some kind of power conditioning. I wouldnt want it just going into the wall
now, is it worth 600.00, I'd say nah. look used for the power conditioning.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
well thats some good advice this is what i was considering buying from cc.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
on sale for 300 dollars.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
Hello everybody.First post.hey I jus purchased the polk m70's refurb from polk audio.Anybody got these? Thanks in advance.
