New to Home Theater. Have a ?
ralphy670
I just purchased the Polk 6005 package and all I can say is wow on the sound. At first I had a Kenwood AVR and it sounded good with this. Yesterday I decided to upgrade that as well to a Harmon Kardon AVR340.
That was the best thing I have ever done. Sorry for all this but I love the sound which brings me to my question. I was wondering if I should upgrade the cables hooking my sources up as well. Also the speaker wire I have is just cheap stuff that came with my Kenwood HTiB four years ago.
Will I notice any difference in sound if I upgrade these items.
Thanks to all who respond.
Post edited by ralphy670 on
IC's & Speaker Wire are part of the whole package ...
So ... imho ... In a word ... Yes ... -
yes! That old speaker wire is probably thin 18ga wire..Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Welcome Ralphy!
Check out www.bluejeanscable.com for well made IC's & Speaker wire at reasonable prices.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Check out cobalt cables as well. also check out audiogon, they usually have some good buys if you stay away from the 5000 snake oil stuff.Monitor Audio GR 60, GR10, GRLCR
Velodyne HGS18
Emotiva MMC-1
Parasound Model 5250
Denon DVD-3800
Pioneer pdp-5070
Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
