HD Audio Question...??
wingnut4772
Ok I am a bit confused here (I will admit) with my audio from my Toshiba A1 over HDMI.
I have my Toshiba set at PCM for the audio output going into my Anthem D2 which processes multichannel via HDMI. My question is: since I have selected PCM out, does it make a difference if I choose say 6.1 DTS vs 6.1 DD in the DVD menu? (SD DVDs). And since my Anthem has the capability to apply Dolby PLIIX to my incoming PCM signal, does it make a difference if I even choose 6.1 vs 5.1 in the SD DVD menu? Thanks
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Nope, doesn't make a difference. You're listening to the L/R downmix (or L/R channels, depending on the player & settings) PCM is just a digital version of the L/R outputs.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
unc2701 wrote:Nope, doesn't make a difference. You're listening to the L/R downmix (or L/R channels, depending on the player & settings) PCM is just a digital version of the L/R outputs.
The PCM out is all channels (5.1)though over HDMI...?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I'm pretty sure it's just a matrixed dolby pro logic downmix- two discreet channels. Your Anthem just takes this like it would the output from, say, a cd player and mixes it into surround sound and sends it to all channels.
If I get the chance I'll check out the toshiba manual & see what I can figure out.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
My Anthem tells me the incoming signal is 5.1.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Huh. I'm stumped then... unless it's decoding it and sending PCM streams for all channels. Have to look that up. If that's the case, it still wouldn't matter what you chose on the the DVD menu.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Yes. The Toshiba decodes into PCM and sends it out to all 5 channels. ThanksSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote:Yes. The Toshiba decodes into PCM and sends it out to all 5 channels. Thanks
Yup. It does this because all hi-def disc formats are in DD+ or Dolby TrueHD and at this time and there are no receivers available that can decode these bitstreams. Additionally, most of these HD discs are advanced content (which means menu sounds and what not are mixed into the audio) and advanced content HD discs will always need to be decoded by the player so these sounds can be mixed into the audio before being sent to the receiver.No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR -
I have found out on my own that some HDMI devices may not pass the DD5.1 signal, so I been doing this. I use HDMI for video only, digital output via Coax or Optical for my audio.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote:I have found out on my own that some HDMI devices may not pass the DD5.1 signal, so I been doing this. I use HDMI for video only, digital output via Coax or Optical for my audio.
If use that route, I believe you have to set digital output to "RAW".Sal Palooza -
Also when using this connection you are not getting the benefit of the higher quality dolby digital + or TrueHD audio tracks. I'm just guessing your Onkyo pre-pro doesn't handle HDMI switching? Does it have multichannel analog in? You could use the player's multichannel analog out to your analog in and enjoy those nicer audio tracks (of course that leaves the bass management up to the player which may not be to your taste).No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
There is lots of info on this over in avsforum.com
I would think you can select what format you want in the hd-dvd menu (dd plus or dd-hd) and then it will output that format over hdmi with 6 channel pcm. You might have to somehow tell the player to use multichannel output over hdmi. I know it works, but now sure how. i only use the multichannel analog outs for dd-hd.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
The problem I had was trying to eliminate an Optical cable by getting the DD5.1 Optical output from the Plasma TV. Feeding the TV with a HDMI cable from my DirecTV Tivo HD recorder.
STB (HDMI) -> Plasma (optical) -> AVR No worky DD2.1 ok / DD5.1 not
OTA (ant) -> Plasma (optical) -> AVR Worky oh YES.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Can't speak for all, but my Samsung BDP1000 sends all channels L/PCM if configured thusly, not a downmix.wingnut4772 wrote:The PCM out is all channels (5.1)though over HDMI...?
HDMI 1.1 can pass LPCM to a receiver so that the receiver can process all included channels as it would through a typical toslink or 5 analog channel input.
You configure the player to send audio via PCM rather than Bitstream to capture the glory of high resolution audio. Use bitstream for standard def DVDs to get the DD/DTS tracks.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
I am still out of touch of this Bluray...HD DVD HDMI technology.....I am not even sure if my processor will be able to manage this when I get my PS3. Please advise.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
