LSI 15 v. Energy RC-70
jmwest1970
jmwest1970 Posts: 846
edited January 2007 in Speakers
I was tired of sitting at the hotel this morning and decided to venture to Milwaukee and listen to some Energy speakers I had saw in an American advertisement yesterday. They had the full line of Energy RC speakers and I noticed that they also carried the Polk and Klipsch. I asked the salesperson for a demo of the Energy speakers and he proceed to oblige me using the new Justin Timberlake CD. Although Justin isn't my cup of tea, it did provide dynamic sound to test the speed of the speakers. My impression of the Energy speakers was that they were very bottom heavy. The bass was muddy and vocals seemed muffuled and the high end was almost non existant. Since the LSI 15s were sitting next to the RC-70s, I asked the salesperson to switch to those and it was like the fog had lifted. The high end was crisp and clear, but not too bright. The vocals were clear and Justin's falsetto sounded exactly like a bad singer should sound. The most noticable difference was the bass. It was strong, clear, and tight. I wanted to look around for a bass drum although I knew there wasn't one around.
I've found my next set of speakers! :D
Post edited by jmwest1970 on
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2007
    Were the LSi's connected to an external amp? If they weren't, you haven't heard anything yet!
    Glad you were happy with them.
    Mike
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    Any idea what the audio's lineage was? By that I mean what was it's source, pre, amp, cables?
    I'd be curious to see if they knew what they were doing.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2007
    Energy's (I have Connoisseurs) have a tendency to sound laid back, especially upon first listening, but that later equates to wonderful listenability. They remind me of vintage AR speakers in that regard. You need to listen to them for an extended period to really appreciate the neutrality in the treble/midrange. No offense, but you couldn't give me 2 pairs of Lsi15's for my C-9's, I love them; but I have not heard the RC series from Energy.
    Bass can be a bit fat, move them out about 36" from the back wall (from the front baffle) and place them on tiles if your room is carpeted. Problem solved.
  • jmwest1970
    edited January 2007
    They were powered by a Denon 2807 Receiver using a Denon cd player as the source. I suspected, and have read, that an amp would make the LSis sing even more than I heard.
    It's American, which is comparitive to BB or CC except they sell furniture and more models/brands. Based on the placement of the speakers, which as 20 ft apart and 6 ft from the listening area, I'd say they don't have a clue about setting up a good listening area. FWIW, the LSis were about a foot farther apart and still sounded wonderful. As far as the other items I'm sure they're using composite connections, and I saw standard no name 14ga speaker wire for all of their connections. To be perfectly fair I'd have to ask them to remove both sets of speakers from their selector and hook them directly to the receiver.
  • fireshoes
    fireshoes Posts: 3,167
    edited January 2007
    Yeah, it's unfortunate to use the selector box but in that type of setting there's not too many other ways to do it. I work at American in Des Moines. The wire is crap and the room is too shallow to get good imaging from the outer pairs of speakers.
    What I've found with the RC70's is that, at least in our demo rooms, they sound pretty tubby in the lineup, but when you pull them off the wall a little bit they sound much better. I do like the finish of the RefCon line as well as the build quality. I also prefer them with Yamaha receivers rather than Denon, although I usually prefer Yamaha to Denon anyway and plenty disagree with me here. ;)
    Sorry about the choice of demo music too. Yuck!
  • cmy330go
    cmy330go Posts: 2,341
    edited January 2007
    I also used to work at the American store in Des Moines. I can honestly say that room does those speakers ZERO justice. And I do know exactly what you were dealing with as all American stores use the same floor plan.
    I personally have the LSI line (see signature) here at home and can tell you they sound absolutely nothing like they do in the store.
    I also have had extended time with the Energy RC-10's here in my home, and they too sounded completely different. In fact I did back to back comparisons with my LSi9s (currently out of rotation:) ) in my 2ch rig, and can honestly say I preferred the RC-10's.
    Just do yourself a favor and get them home for a listen before making your selection. Trust me...you won't believe how different they will sound.
    Later.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2007
    LSI speakers are great sounding, although these were underpowered with just the Denon, I would take them over the others.
    RT1
