new construction: in-wall speakers
rixster
rixster Posts: 2
I'm not an audiophile, but am building a new house and just realized that I should make allowance for speakers. I'm running 14 gauge speaker wire in the walls and will want in-wall speakers in the front and in-ceiling in the rear because of the layout of the room. House budget is shot already :-( so I need to keep the cost way down.
Can I use the low-end RC55i for front and RC60i for rear? Thoughts?
What about a subwoofer? Does it need to match the speakers?
Post edited by rixster on
  • rixster
    rixster Posts: 2
    edited December 2006
    I already gave the contractor a spool of CL3-14GA for installation. I did get the brackets though, good advice.
    I can't use an infinite baffle sub, so need something that I can stick into a corner of the room.
  • wallstreet
    wallstreet Posts: 1,405
    subs don't need to be timbre matched since there isn't any mids or highs coming out sub. Don't sweat the 14ga selection. You'll be fine as long as the runs are under 50ft. Just make sure you run over all your possibilities for TV placement since once the inwalls go in, they stay in. And you will absolutely need a sub with those speakers.
