EQ to help brightness of the 2.3's?
hifidigital
I've been mainly using my 2.3's in a HT setup and have been listening to more 2 channel music recently. For HT, I'm satisifed with what I'm hearing, but for stereo music the speakers seem too bright. I don't have the cash to spend on replacing the (6) tweeters, so I was wondering if hooking up an EQ (which I already have) might help tone down the brightness?
Post edited by hifidigital on
that is one thing an EQ can doDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
So, how should I hook it up to my Denon AVR-1905? Its a 2 channel EQ and I'm really only concerned with front l/r.
http://www.denon.ca/hapdfs/avr1905mane.pdf -
What would be accomplished by buying just two replacement tweeters, and placing one into each speaker's uppermost tweeter bay? Then buying the other four, perhaps two at a time, at your leisure. Good idea? Bad idea?
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
i'm with the others.. replacing the tweeters will help. i'd do two at a time.. even it takes you a while to replace them all. it will help tame that nasty brightness better than an eq.
what interconnects are you using? that will make a difference too..PolkFest 2012, who's going>?
I'm not totally opposed to doing that, but I have an EQ that I figured I'd try first, and heck, its a free solution (if I can figure out how to get it hooked up).
If that doesn't work out, I may take your advice and do them 1 pair at a time. -
It's been a long time since I hooked up an EQ, but I think the EQ is installed between your source (CDP or DVD) and the receiver. You may find the harshness comes from around the 13KHz range, tweek that down about a couple of dBs to suit your taste.Carl
