EQ to help brightness of the 2.3's?
hifidigital
hifidigital Posts: 26
edited December 2006 in Vintage Speakers
I've been mainly using my 2.3's in a HT setup and have been listening to more 2 channel music recently. For HT, I'm satisifed with what I'm hearing, but for stereo music the speakers seem too bright. I don't have the cash to spend on replacing the (6) tweeters, so I was wondering if hooking up an EQ (which I already have) might help tone down the brightness?
Post edited by hifidigital on
  • hoosier21
    hoosier21 Posts: 4,416
    that is one thing an EQ can do
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • hifidigital
    So, how should I hook it up to my Denon AVR-1905? Its a 2 channel EQ and I'm really only concerned with front l/r.
    http://www.denon.ca/hapdfs/avr1905mane.pdf
  • Loud & Clear
    Loud & Clear Posts: 1,538
    What would be accomplished by buying just two replacement tweeters, and placing one into each speaker's uppermost tweeter bay? Then buying the other four, perhaps two at a time, at your leisure. Good idea? Bad idea?
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • danger boy
    danger boy Posts: 15,722
    i'm with the others.. replacing the tweeters will help. i'd do two at a time.. even it takes you a while to replace them all. it will help tame that nasty brightness better than an eq.
    what interconnects are you using? that will make a difference too..
    PolkFest 2012, who's going>?
  • hifidigital
    I'm not totally opposed to doing that, but I have an EQ that I figured I'd try first, and heck, its a free solution (if I can figure out how to get it hooked up).
    If that doesn't work out, I may take your advice and do them 1 pair at a time.
  • schwarcw
    schwarcw Posts: 7,358
    It's been a long time since I hooked up an EQ, but I think the EQ is installed between your source (CDP or DVD) and the receiver. You may find the harshness comes from around the 13KHz range, tweek that down about a couple of dBs to suit your taste.
    Carl
