Glass shelf project
Early B.
I have an extra glass shelf for my TV stand and I want to add another tier to the TV stand. The glass shelf would be set on top of the existing top shelf supported by four metal posts that can handle 600 lbs. each. I want to place my TV on top of the glass shelf which is roughly 16" x 48" and is 1/4 inch thick. The TV weighs 73 lbs. Will the glass shelf support the weight of the TV?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Yes, until it breaks.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
So the legs would be on the glass of the other shelf, if I understand correctly. If so I wouldn't do it, you're putting lot of force per square inch on the glass under the legs of the other shelf.
You may be buying 2 shelfs 1 TV when the first shelf fails the second comes down the TV hits the floor. Or you're looking for an Upgrade reason?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I think I would be looking at the psi of the TV and the glass. Anything heavy I would be leaning toward a tempered or laminated glass product. Just my opinion.Michael
NORTH of 60° -
disneyjoe7 wrote:So the legs would be on the glass of the other shelf, if I understand correctly. If so I wouldn't do it, you're putting lot of force per square inch on the glass under the legs of the other shelf.
The existing top shelf is designed to hold something like 200 lbs and is screwed directly into the metal stand on all four sides, so the additional weight should not be an issue.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
janmike wrote:I think I would be looking at the psi of the TV and the glass. Anything heavy I would be leaning toward a tempered or laminated glass product. Just my opinion.
It's tempered glass.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Oh, the reason I'm considering doing this is because I don't have enough shelf space on my TV stand for all of my components since I consolidated my 2-channel and HT systems. I need space to add a pre and CDP. Right now my CDP is sitting on the floor supported by a makeshift amp stand.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
So if I understand you right, the legs of one are connected to the legs of the other. Then I don't have an issue with that. My caution is with glass between the legs of the second shelf above, which doesn't seem to be the case.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:So if I understand you right, the legs of one are connected to the legs of the other.
Not exactly. The legs of the top shelf will rest on the shelf beneath it (currently the top shelf). I'll find a way to adhere them to the shelf.
Here's a pic of the nearly identical TV stand in this thread (see post #12):
http://www.polkaudio.com/forums/showthread.php?t=44192
Imagine the inner shelf in this pic being suspended by four metal legs on the top shelf.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early, I'm not comfortable with it, I wouldn't do it. Maybe you're more of a risk taker then I am.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
At 48" long and 73 pounds I would not do it. To me the lenght is too much based on the weight of the TV and the thickness of the glass.Michael
NORTH of 60° -
I have to admit that I would be too scared to attempt something like that. If it is of similiar size as the link that you provided I don't think it would be doable with 4 legs......maybe 6 though. I also thing that you may need some crossbracing network that goes from post to post that the glass sits on to further disperses the weight. Just my thoughts.
Good luck,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
I would go with a wall mount or a floor bracket to get the tv above the shelf, Free up the whole top shelf. One chip in the glass with the tv on it and you are gone.>
Midnite Mick wrote:I also thing that you may need some crossbracing network that goes from post to post that the glass sits on to further disperses the weight. Just my thoughts.
Yeah, I think I'll add some bracing.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Let me add that the middle shelf of my TV stand is exactly the same as the shelf I plan to add. I currently have about 70 lbs of gear on this middle shelf and it is only being supported by four tiny metal brackets.
The main question is whether a 16"x48"x1/4" tempered glass on metal legs can easily withstand the weight of my TV. The weight would be distributed fairly evenly across most of the length of the glass. If the answer is "yes," I'm good to go. If not, it's back to the drawing board.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Tempered glass is tough as ****...........I've got a piece of scrap 3/8 inch thick 4 foot long that I can't break throwing it down on concrete.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I decided to try it. Hell, the glass shelf weighs about 20 lbs. by itself, so it should be sufficient to hold 73 lbs. I'll double check with a local glass dealer before I do it, though.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
If the legs are placed close to the contact piont of the TV you shouldn't have any problems. Tempered glass is tough as hell.
OK, got her done.
Here are the BEFORE pics...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
...and these are the AFTER pics...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
The TV sits 9.5" higher than before. From the seating position it doesn't make much difference.
I haven't tested the HT system yet to see if the center channel at ear level makes a difference.
The glass is resting on four metal legs. I used silicone to adhere the legs to the shelves, both top and bottom. The shelf is not quite as sturdy as I would like (I don't want any movement in it at all), but I believe I have a partial solution -- I'm gonna strap the TV down. This TV was designed to be strapped down to a Sony stand so it wouldn't accidentally fall forward. Doing so will give me a bit more peace of mind.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
amulford wrote:If the legs are placed close to the contact piont of the TV you shouldn't have any problems.
I made sure I did this. Most of the weight of the TV is in the back, so I placed the back legs closer together and the back of the TV is directly on top of these legs.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Looks great!!! Man those VMPS are monsters!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Looks ok to me, thanks for the update. I think you're fine due to the closeness of the weight of shelf 2 to the cross support of shelf 1.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Dennis Gardner wrote:Looks great!!! Man those VMPS are monsters!
You oughta see 'em when they take their shirts off. Pure muscle, man!HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Lookin damn sweet Early. Congrats and enjoy.From one monster floor standing lover to another.HT SYSTEM-
lsi 9's -
Cool looking room Early!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
OK, now I can definitely state that putting the center channel speakers at ear level makes a positive difference. More clarity, for sure.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
How did I not see the photos until now? Very nice...glad everything worked out so well for you.
Consonance cd120T
Usher CP 6311
Early B. wrote:The shelf is not quite as sturdy as I would like (I don't want any movement in it at all), but I believe I have a partial solution -- I'm gonna strap the TV down. This TV was designed to be strapped down to a Sony stand so it wouldn't accidentally fall forward. Doing so will give me a bit more peace of mind.
nice look.
is the instability from the legs swaying? i mean, it might just be the camera angles, but the legs don't look plumb in relation to the speaks.
if that's the case, you need some sort of triangulation between the top and bottom shelves. if you can still lift the top shelf off you can probably do this pretty easily without losing the design look of what you've got now at all.
blu tack might be worth a try for the tv if you haven't gotten to the strapping yet.
scottnbnj wrote:blu tack might be worth a try for the tv if you haven't gotten to the strapping yet.
TV has been strapped to the stand, so it cannot be tipped over.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
