SRS 2.3's Sound Levels
westdr1
westdr1 Posts: 12
edited December 2006 in Vintage Speakers
I have a pair of the 2.3's that I have finally been able to put back into action today after replacing the amp. I bought the NAD C272. I noticed the sound on the right channel to be substanially muffled in comparsion to the left. It does not appear to be distorted and I am unable to see any physical damage on any of the speakers. I noticed there were some problems mentioned on the polyswitchs. Is this characteristic of the polyswitch.
I am in the process of rebuilding the cross overs.
Any speaker cable recommendations would be appreciated. I am currently using Monster that I bought when the speakers were new.
TIA
Post edited by westdr1 on
  • george daniel
    george daniel Posts: 12,096
    Assuming that you have ruled out the amp as the problem,the poly's are for tweeter protection and usually reset,check your source,cables,etc. Good luck
  • westdr1
    westdr1 Posts: 12
    George;
    Thanks I will check them.
    F1nut Posts: 51,747
    I've heard others report the same issue, but I can't recall anyone posting a solution other than placement issues. Can you give us a description with measurements of your layout?
