NEED HELP!!!Hum noise from front and rear speakers
thai
Post edited by thai on
Are you in the US?
if you have a grounding plug, Try putting a ground Isolation plug on the AVR. -
What is it all connected to?My first guess is the sub....try a cheater plug and go directly to the wall outlet.Give us a better overview of how your gear is wired and we can better help you.Power conditioner? Cable box?HT SYSTEM-
lsi 9's -
One suggestion I was given was to disconnect your cable TV wire. It does indeed give off a hum in some systems. Is this a new problem, or new equipment? Fluorescent lights, wireless phone, and electric motors can do the same thing.
Good luck let us know how you made out
Ben -
Now I am in Thailand with 220 Volt, 50Hz. The power line here doesn't have a seperate ground. I have tried to seperate the power cords from the speaker cables but that didn't help. I have changed the male plug to Hubbell and changed female plug to Wattgate. I have done that because I thought it was the power cord that gave me this hum noise but that didn;t solve the problem. Now my AVR3805 doesn't connect to any other unit becasue I want to isolate the receiver. Yes, the noise is still there!!!! Any idea how can I ground the AVR3805??
I would call Denon directly on this. They have an office in Singapore. It's website can be found HERE
ben62670 wrote:One suggestion I was given was to disconnect your cable TV wire. It does indeed give off a hum in some systems. Is this a new problem, or new equipment? Fluorescent lights, wireless phone, and electric motors can do the same thing.
Ben
I had a hum into all my speakers when I connected the cable line directly to the Digital Cable box, because technician told me to connect it directly. When the tech left I connected the cable to my Monster Power bar 2100 and then out to my box, BINGO:cool: hum gone!Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
