NEED HELP!!!Hum noise from front and rear speakers
thai
thai Posts: 3
:confused: I have Denon AVR3805 and hooked it up with Polkaudio speakers (Monitor 60, monitor 30, CSi1 and PSW12). I just noticed the hum noise coming out from speakers, especially the front and rear speakers. I turn off all other units but the hum noise is still there with AVR3805 on. The hum sound can be heard when I turn on the AVR3805 and turn the volume all the way down to 0. Any suggestion to get rid of this hum noise.:confused:
Post edited by thai on
  • amulford
    amulford Posts: 5,020
    edited December 2006
    Are you in the US?
    if you have a grounding plug, Try putting a ground Isolation plug on the AVR.
    tonyb Posts: 33,072
    What is it all connected to?My first guess is the sub....try a cheater plug and go directly to the wall outlet.Give us a better overview of how your gear is wired and we can better help you.Power conditioner? Cable box?
  • ben62670
    ben62670 Posts: 15,969
    One suggestion I was given was to disconnect your cable TV wire. It does indeed give off a hum in some systems. Is this a new problem, or new equipment? Fluorescent lights, wireless phone, and electric motors can do the same thing.
    Good luck let us know how you made out
    Ben
    Ben
  • thai
    thai Posts: 3
    Now I am in Thailand with 220 Volt, 50Hz. The power line here doesn't have a seperate ground. I have tried to seperate the power cords from the speaker cables but that didn't help. I have changed the male plug to Hubbell and changed female plug to Wattgate. I have done that because I thought it was the power cord that gave me this hum noise but that didn;t solve the problem. Now my AVR3805 doesn't connect to any other unit becasue I want to isolate the receiver. Yes, the noise is still there!!!! Any idea how can I ground the AVR3805??
  • amulford
    I would call Denon directly on this. They have an office in Singapore. It's website can be found HERE
  • hamzahsh
    hamzahsh Posts: 439
    Ben
    I had a hum into all my speakers when I connected the cable line directly to the Digital Cable box, because technician told me to connect it directly. When the tech left I connected the cable to my Monster Power bar 2100 and then out to my box, BINGO:cool: hum gone!
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
