Up-converting DVD players....
shawn474
shawn474 Posts: 3,052
edited December 2006 in Electronics
For the up-converting DVD players (I just ordered the OPPO 981), do you HAVE to use the HDMI cable to get the "up-conversion" or can you use and S-video cable? I realize that there may be a difference in image quality, but I cannot access the crawlspace where my wires are run because I am still recovering from back surgery. Also, I need a 20 to 25 foot HDMI cable and don't have the funds right now. Just wondering if the S-video cable that is presently run will still up-convert the DVD's or if the HDMI is required to do so. Thanks for your help.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • PolkThug
    PolkThug Posts: 7,532
    I believe S-video only does 480. Get your HDMI cable from a computer store.
  • shawn474
    PT,
    Why is that? Are they cheaper there? I was going to just order one from monoprice.com because with the "modestness" of my system, I don't believe that a better cable will necessarily produce a noticable difference.
    Thanks.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • Ricardo
    Ricardo Posts: 10,634
    You can get a HDMI cable that lenght for less than $40; just shop around.....and get somebody to help you hook it up.
    Someone posted recently a link to a cheap cables store...too lazy to look for it now.
    Found it; and guess what...it was YOU :) Post # 5
    http://www.polkaudio.com/forums/showthread.php?t=46883&highlight=cheap+cables
    SOPA
  • PolkWannabie
    PolkWannabie Posts: 2,763
    The 981 ships with a fairly decent HDMI cable ... although it's not 20-25' ... I think they have longer cables available and while it's not videophile category it's also not sphaghetti either ...
  • Sami
    Sami Posts: 4,634
    Digital cable, the signal either gets there or it doesn't. You're not going to get better picture with "better" cable so don't waste money on expensive HDMI cable.
  • aba4430
    aba4430 Posts: 80
    I bought two of these cables. They appear solid and well finished. Plus I have had no issues with performance. I have these going to my Sony from a cable box and a Panasonic DVD-S97 upconverting player. Price is reasonable.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024002&p_id=2219&seq=1&format=2&style=
    aba4430
  • shawn474
    HTrookie,
    Yeah that was me. They happen to be out of stock of the one that I need. For the time being, I will settle for the S-video connection until I can afford and be able to run the HDMI cable. I would ask my wife to do it but I have everything neatly run and in a jacket and am nit-picky about that kind of thing.
    Sami, I know there is some debate to that, but like I said with my system I don't think that a better cable will make a noticable difference.
    Thanks everyone.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • Sami
    Sami Posts: 4,634
    shawn474 wrote:
    HTrookie,
    If you see a difference, it will be very noticeable. If someone sees "a slight difference" in PQ by swithing to more expensive cable, it's all in the head, not on the screen. Buy a cheaper cable with confidence, you're not missing anything in PQ.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    As far as fishing the cable around, if you didn't give the old cable some cable nails you could use the old cable to fish in the new cable. Just tape the ends together and pull the other end out ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dipiazza
    dipiazza Posts: 363
    Get the cheapest one you can find. Digital is digital. Its eithere there or it isnt. never buy a pricey optical cable either. No change in picture quality.
    btw shawn i know jack about hdmi...
    -Jake
    Get better fool!
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • mlhm5
    mlhm5 Posts: 217
    Amen!
    "...experts are in agreement that most cables that claim to improve the sound of audio equipment don't. Even cables costing thousands of dollars per foot are often little more than sonic snake oil, experts say."
    http://www.nytimes.com/library/tech/...es/23down.html
    "you may choose to pay outlandish prices to get something that looks amazing, and demonstrates to everyone how much money you have, but it will not make a magical difference to the sound, there will be few (if any) real differences in the electrical characteristics, and it will sound much the same as "lesser" cables, selling at perhaps 100th of the price."
    http://sound.westhost.com/cables.htm
    "...all well designed interconnects sound identical."
    http://sound.westhost.com/cablewhitepaper.htm
  • shawn474
    Jake, I'm trying man. This **** is no joke!!!!!
    This wasn't what I wanted to happen; I think this forum has has its' share of cable debates. My question was just where to find a cheap one while monoprice is out of stock. I agree with everyone's assertion so far that cables don't make a difference, but I can also be honest in telling you that the only reason I won't compare is because I don't nearly have the money to invest in them. So, in my mind, I may just be trying to justify it by saying "more expensive cables don't make a difference." There are many that I have heard and respect that say they do make a difference and many that I have heard from and respect that say they don't. All I know is that my budget won't allow me to convince myself that more expensive is better so my mind is made up.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • disneyjoe7
    I don't think Digital is Digital all the time, I know Digital can work with errors so this has to be bad for any input receive. The more errors the worst the output is. IMHO
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • McLoki
    McLoki Posts: 5,231
    I will stay out of the cable debate except to say - form your own opinion on the matter.
    For the cheap HDMI cable - Blue Jeans Cable has some pretty cheap (not monoprice cheap, but better than best buy).
    25' is about $52
    Michael
  • mark g. nelson
    mark g. nelson Posts: 134
    I agree I have 2 Blue Jeans 15' HDMI cables and they are great quality and their service is the best I've seen. Less then 48 hours on delivery.
  • Ferres
    Ferres Posts: 310
    Then the error would more likely come from the source.
    The big issue with HDMI cables before where the bad connectors that caused 'drops'. I believe it's all got ironed out by now.
    If you want better picture quality, start with the power. Mains noise are big culprits.:p
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • disneyjoe7
    Ferres,
    I also work in another field and digital optical or coax can have errors (bad cable) I would think also refraction of light in optical cables, vs poor coax cables with impedance issues crappy connections would have a negative effect on sound.
    BTW drops are error // too many errors to true signal.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    That's why I said if there is a difference, it will be very visible. Errors will be... so the cable either works or doesn't, if it drops packages it doesn't work. :)
    I have an opinion about audio cables as well but I'm stating this only for HDMI cables, I don't either want to get into the holy war of audio cables.
    I can't remember where I bought mine but here are some cheap ones for 25ft:
    http://www.cablewholesale.com/specs/hdmi-01125.htm
    http://www.microwaves.com/USCP/HDMI25Price.html
    http://www.cablesshop.com/hdmatomaca25.html
    http://www.hammerimports.com/item.php?id=171&name=HDMI_Cable_HDMI_to_HDMI_Video_Hi-Grade_24K_Gold_Tip_CL_Rated_25_Feet
    If you have a really long run and the connection starts to drop, there is always this:
    http://www.riteav.com/product_info.php?cPath=47_48_58&products_id=239&osCsid=d696851c7864164c904bcff46c565ed3
    I just wonder how it works as described, maybe some of the EE's here can share some light to it:
    "Uses power from the HDMI bus to amplify an HDMI signal"
