Removing super glue
cindy100
Any tips for getting super glue off your skin and counter top? Once it spilled, I thought I got it all cleaned off but
Thanks!
Cindy
Cindy
Post edited by cindy100 on
Try acetone, which some nail polish removers have in them.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
If you didn't glue anything to your skin, don't worry about getting off. When I used to play bass a lot, i'd put superglue on my fingers & spread it around to keep my skin from peeling off (the trick was to not glue your fingers to each other). It'll come off in a day or two.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
dkg999 wrote:Try acetone.
DING!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
ACETONE will take it off anything. Just make sure you don't take the finish off something else.
