New guy, New install ? THANKS and HI
tnholly
A few quick questions, to help with my new install.
1. Is Bi wiring really worth the effort?
If so what wire gauge difference should I use between
Low and high end
2. I am using only surround at present (monitor 40's)
Is it worth the investment for surround back?
Can I wire my rear monitor 40's for the surround back?
3. Based on my current set-up which PWS should I invest in (Polk of course).
I know I'll get good advice, and appreciate your welcome and help
THANKS
Low and high end
THANKS
ONKYO TX-SR603X
DS-A2 iPod dock
Polk Monitor 70 - main
Polk Monitor 40 - surround
Polk CS1 - center
Polk PSW12
DS-A2 iPod dock
Polk CS1 - center
Polk PSW12
Post edited by tnholly on
Welcome and congrats on your nice system.
Did you happen to have a budget in mind for your subwoofer? If you do a search in the forum, you'll find the subject has been discussed many times already. Many favorite subwoofer brands including SVS, Velodyne, HSU. -
i've found that bi wiring is not worth it.. some people will agree, and other's will disagree. try it if you are really curious.. but you may not hear a difference. in terms of sub's. get the biggest baddest you can afford. your choice on brand.PolkFest 2012, who's going>?
