HDMI Problem
harold280z
I can't run my HDMI cable from my Comcast Motorola Box DCT-66412 to my Pioneer Elite Receiver VSX82TXS I get and error message which says Comcast does not support HDMI switch. Has anybody got a fix for this problem? HDMI only works when I connect to the TV from the Cable Box. I really want to use the HDMI in my receiver I think that would be the best set up. I went to Comcast's web site and here is what I got:
Some cable TV set-top boxes with HDMI outputs don't deliver a picture
to
displays with HDMI inputs. What is the problem, and is there a
solution?
In some cases, the set top box software does not activate or support
the
HDMI port. In other cases, cable TV set-top boxes don't work correctly
when
used in conjunction with an A/V receiver (but will typically function
correctly when connected directly to a TV or monitor). Investigation of
some
of these devices reveals that this is caused by an error in the way
these
set top box devices implement HDCP. Specifically, some of those boxes
do not
support "HDCP repeaters" (devices that pass along the signal to another
device) such as an A/V Receiver or switch. We believe that this may be
a
problem in the initial versions of these products, and in some cases
there
is new firmware available that fixes this issue in HDMI (newer versions
may
already have this fix). We have been actively working with
manufacturers to
resolve these problems. We suggest that users contact their cable
operator
and request the new software to address these issues.
My set up is the following
Bedroom sounds!
Pioneer Elite DVD DV-46AV
Sony Bravia 40XBR1
Motorola DCT-6412 Digital Cable Box With DVR
Polk RTi 8's front
Polk T20e rear
Polk RM 202 center
Polk PSW 10 sub
to
solution?
the
when
some
these
do not
a
there
may
manufacturers to
operator
Bedroom sounds!
Sony Bravia 40XBR1
Polk RTi 8's front
Polk T20e rear
Polk RM 202 center
Polk PSW 10 sub
Bedroom Stuff 5.1
Pioneer Elite VSX-82TXS
Pioneer Elite Blue Ray BDP-05FD
Monster Power HTS3500
Harmont Remote 880
Sony Bravia KDL40S2400
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Martin Logan Abyss Sub:D
::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite DVD DV48AV
Pioneer Elite 910HD
Monster Power HTS3600
Harmony Remote 688
Warfedale Diamond 8.4 Front
Warfedale Diamond 8.2 Sides & Rear
Warfedale Diamond 8 Center
SVS PB12-Plus/2 Sub:D:D
Harmont Remote 880
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite 910HD
Harmony Remote 688
Post edited by harold280z on
In the short run, you may just be out of luck. From what I've been told, the HDMI out from Comcast is still at version 1.0. The firmware updates will probably upgrade to a newer version, but it will probably take a while.Tschüss
Zach -
call the cable company.. they should help you out.PolkFest 2012, who's going>?
They say its not their problem, I got a call in to Motorola I'll seedanger boy wrote:call the cable company.. they should help you out.Bedroom Stuff 5.1
Harmont Remote 880
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite 910HD
Harmony Remote 688
You're probably going to be caught in a circle of finger pointing. If it works without your receiver in the mix, Motorola and Comcast are going to point at Pioneer.
Does the Pioneer have a USB Port for software upgrades? I would imagine if enough people requested it (and why wouldn't they), Pioneer would create a driver for this cable box. -
Personally I prefer running video sources direct to video displays ...
PolkWannabie wrote:Personally I prefer running video sources direct to video displays ...
Dito.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
