Need Help to choose CDP?
GATOR3000
Hi all,
Looking to buy a new CD player. The CD Players below are my three choices and not necessarily in that order:
ORIGINAL A8T CD Player (Tube and SS)
SHANLING T80 CD Player (Tube only)
Cambridge 640C v2 CD Player (SS)
Need help to choose one. Which one would you buy? All help is welcome and appreciated.
Gator
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Original A8T CD
Post edited by GATOR3000 on
Well i don't know about the others but i'm a fan of the Cambridge equipement hey if you can afford it give music hall and rotel a look as wellChicomorales:)
I haven't heard of the Shanling T80. Did you mean the T100?
Also, look at the Jolida JD100A and the Eastern Electric MiniMax. Both are tube output and have my recommendation.Political Correctness'.........defined
President of Club Polk -
+1 on the Jolida thats my next purchase.
F1nut wrote:I haven't heard of the Shanling T80. Did you mean the T100?
No man, I'm talking about the Shanling T80, The T100 is way out of my range, but Shanling sure makesnice products.
Cheers
Theatre System 5.1
Original A8T CD
MONSTER CABLE MP-HTS3500MKII Powercentre -
Take a look also at the BADA HD-22; tubed output and I am very happy with it; as good as the stock Jolida 100.
http://www.pacificvalve.us/BDHD22.html_________________________________________________
Zombie just posted a link to a nice rotel 1072 CDP, if that's hifi enough for you. It's a great deal at $350 or whatever the guy is asking.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
did you make up your mind already? have you considered rotel or even music hall??? kinda curious as why you are limiting your choice to those 3???Chicomorales:)
Chicomoralessxm wrote:did you make up your mind already? have you considered rotel or even music hall??? kinda curious as why you are limiting your choice to those 3???
Hey Chico……….wazzzzzzzzzz……Uppppppppppp??? OK, to answer your question, I didn’t limit myself to only those three models I have listed. I have been doing a lot of research quality/price/SS/tube/integration with my system/availability………….blah…..blah…….blah. Anyway these are the three models I came up with.
Just to keep you informed I have ordered the “Original A8T CD player”. Why I have chose Original A8T CD player is:
1. Price is right. What I mean the unit is coming from USA and I have to pay duty and taxes and I have checked with Canadian customs and the total fee is reasonable.
2. The A8T is build like a tank. The quality is awesome. It weights 20.9 lbs.
3. It has a huge heavy duty toroidal transformer. WOW……..this is a monster!
4. It has two separate outputs. One is stand alone SS output the other is totally separate tube output that uses 2 12AU7’s tubes.
5. It is easy to roll tubes in this CDP. The 12AU7 tubes are very common and relatively inexpensive. The A8T uses only two of them and replacing stock 12AU7 tubes with NOS like Mullard, Telefunken, Amprex, Tung-Sol just to name a few, will totally change the sonic signature of this CD player. So I have a lot of room to play around, experience and enjoy different kinds of music.
In a nut shell that is about it. I just didn’t see myself buying a CD player that is “plug and play” type. I wanted a CD player which is more versatile like the Original A8T.
I did look at the new “Cambridge 840C CD player” with the 24bits/384kHz upsampling. Very nice unit, but way overpriced for my taste and no tubes. I have auditioned this unit for 2 hours. Like I said, very nice sound, but there was no feeling in it (IMO). The music coming out through this CD player was very clean, detailed, but cold! There was so much detail that it sounded almost unnatural if you know what I mean. We all have different ears and tastes for music.
Anyway, hope I satisfied your curiosity and answer your question why I have chose those three CD players?
Cheers
Gator
Theatre System 5.1
Original A8T CD
+1 on a rotel 1072. Easily in the neighborhood of the very nice DAC's like the Bel Canto and Benchmark.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I can recommend the Jolida, and the Ah! 4000...
I have both and love them both ...very different machines, but that`s why I have both..!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I auditioned a lot of cdps before I settled on the Jolida..I highly recommend it!2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
what are the other components that your going to use in this 2 ch set-up ?
Depending on what the rest of it is made up of,
you can find a cdp that fits into that paticular rig with better synergy...
I have found that after I modded the AH! (upsampler, tubes, dynamat. power cord, etc..) that it is a very good CDP.
The Jolida is also a great cdp...I plan to do the upgrade mods on it soon also..
I have never heard a shanling cdp, but really like what I see..!!
also there is a write up of the Bada in this months Affordable Auio E-zine, if I remember correctlyCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
beardog03 wrote:I can recommend the Jolida, and the Ah! 4000...
Yes, I do agree there are a lot options to buy a CD player. I did consider the Jolida 100A. Very nice player, but would of liked the one with Level 1 upgrade at least. This would put me right over my budged. Canadians are limited to lot of audio gear unless one wants to fork out big $$. Like I said the Original A8T CDP was reasonably price with the options I was looking for.
Im going to upgrade signal path, power cord, tubes blah .blah ..blah .ultimately this will be sweet sounding CD player in this price range.
Gator
Theatre System 5.1
Original A8T CD
beardog03 wrote:what are the other components that your going to use in this 2 ch set-up ?
Thanks bro, very good suggestions on CD players. I have looked at Bada CD players too, very nice machines. The front plate looks almost the same as the Jolida 100A CDP.
For now the rest of my 2 channel rig is Antique Sound Lab AQ 1003 DT integrated tube amplifier (30 wpc) with Rti8s or Lsi15s. Ultimately I will be looking for more efficient speakers, havent decided which one as yet.
Hope my Original A8T CDP will come before Christmas. I will give you guys a full report/opinion on this player after I get it.
Cheers
Gator
Theatre System 5.1
Original A8T CD
cool..!
look forward to hearing how it goes...
I agree with you on te level 1 mod.
I`m getting ready to mod my Jolida as soon as funds are available
I am also interested in what speaker choice you make..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
