What can I add to Polk M10?
Friend gave me a new pair of M10's. Thought I would add a center speaker and a sub. Considered a CSi3 and a PSW10. Anyone have any other suggestions? Really would appreciate the help..
Post edited by bears on
are you wanting to use them in a home theater set up? if so.. adding a center and sub is important. YOu may want to go instead with a larger center. such as a CSi5. or the Monitor 10's may overpower the smaller center.PolkFest 2012, who's going>?
danger boy wrote:the Monitor 10's may overpower the smaller center.
I think he might be talking about these...
http://www.polkaudio.com/homeaudio/products/m10/
but not sure, need more details...AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
tommyboy wrote:I think he might be talking about these...
ahhh ok. never mind then. continue as you were.
How big is the room? CS-1 and a psw 202 maybe. No one on here seems to like the psw 10. I've never had one so I can't really say. I do have a cs-1 though. It was too small for my room (12 x 25) but may be ok for a smaller room.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
CSR or CSi25 would be the best match. If you are going to run 6.1, pick up another pair of M10's - one for front center, one for rear.
Any Polk sub would be a good match.
Cheers,
More info: room size is 10x12.. spare room converted to my "play room"... Will use mainly for Xbox 360 on a 32" LCD HDTV...5.1 receiver is Sony STR-DE835.The m10's are ok but i think that using a good center will make all of the difference..The psw10 has good reviews and will pick up majority of bass..will probably add rears at a later date. Right now i want speakers that are compatible.
You would probably do better with a psw303, its pretty solid for the price and would go with your M10s. Center try wat russ has said. Get a CSR and anoter pair of M10s for surrounds. Decent 5.1 for games and movies in a room that small.
Good luck!Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
